Unicode strings and Indigo Variables
Tue Aug 14, 2018 6:55 am
mundmc offline
Sorry if I am being thick...
1) I store info for some python code in a dict
2) I was storing that dict in an indigo variable using str(myDict)
3) I was retrieving the indigo variable into a python script, converting it from a string to dict using myDict = ast.literal_eval()
4) The contents of the dict appear to be Unicode now, causing problems in my script
Jay instructed me to convert the dict to json before storing in an indigo variable
Question: How do I reproduce this Unicode-related problem on my python editor outside of indigo?
I tried this
 import ast
unicodeString = unicode("{'key1':'value1', 'key2':'value2'}")
uDict = ast.literal_eval(unicodeString)
But it yields this:
 >>> uDict['key1']
'value1
Not this:
u’value1’
<- which seemed to be happening when I pulled the string from Indigo before
Thoughts?
Tue Aug 14, 2018 9:40 am
Re: Unicode strings and Indigo Variables
Don't use ast.
import json
r = json.dumps({'key1':'value1', 'key2':'value2'})
uDict = json.loads(r)
print uDict['key1']
Tue Aug 14, 2018 9:43 am
this works for me:
import json
theDict={'key1':'value1', 'key2':'value2'}
indigo.variable.updateValue("yourvarname",  json.dumps(theDict))
# if you like yo can look at it in a formatted way:
indigo.server.log( json.dumps(theDict, sort_keys=True, indent=4))
# and getting it back:
theDict = json.loads(indigo.variables["yourvarname"].value)
Tue Aug 14, 2018 10:58 am
mundmc offline
So if I do,,,
import json
myDict = {'key1':'value1', 'key2':'value2'}
r = json.dumps(myDict)
... I get this:
 >>> myDict
{'key2': 'value2', 'key1': 'value1'}
>>> type(myDict)
<type 'dict'>
>>> uDict
{u'key2': u'value2', u'key1': u'value1'}
>>> type(uDict)
<type 'dict'>
>>> r
'{"key2": "value2", "key1": "value1"}'
>>> type(r)
<type 'str'>
So I suppose I’m wondering how best to put a dict into an Indigo Variable so I can retrieve it with a python script and make it act like the dict when I made it, without all the u’’ business, which screws with my string operations and logging?
Tue Aug 14, 2018 11:24 am
This line:
isn't doing what you think probably. It's converting this non unicode string:
to a unicode string:
u"{'key1':'value1', 'key2':'value2'}"
But none of the values inside are unicode - it's just one long non-unicode string. So when you use the ast module to reconstitute the string into an actual dict, it's reconstituting the dict values as non-unicode strings.
However, if you did this:
uDict = ast.literal_eval("{'key1':u'value1', 'key2':u'value2'}")
Where you're explicitly making the strings unicode strings, then:
>>> uDict["key1"]
u'value1'
Here's a brief cheat sheet of string vs unicode Python:
>>> my_string = "I'm a standard string"
>>> my_string
>>> my_unicode_string = u"Here's a native unicode string"
>>> my_unicode_string
>>> unicode(my_string)  # convert standard string to unicode string
u"I'm a standard string"
Tue Aug 14, 2018 11:35 am
myDict = {'key1': "value1", 'key2': "value2"}
indigo.variable.updateValue(123456789, value=json.dumps(myDict))
# At this point, the value of the Indigo variable with ID 123456789 is
#  {"key2": "value2", "key1": "value1"}
# Now, to get it back
myReconstitutedDict = json.loads(indigo.variables[123456789].value)
Now, perhaps this is where you get tripped up. This is what myReconstitutedDict looks like:
>>> myReconstitutedDict
because JSON string values are always returned as unicode strings. But this should make no difference for your script since in pretty much every other respect unicode strings can be used interchangeably with non-unicode strings.
If, however, something in your script isn't liking that, then you can convert the unicode string back to a non-unicode string:
>>> str(myReconstitutedDict["key1"])
'value1'
assuming that there aren't any non ascii characters in the string.
If you would be more specific about the string operations and logging that isn't working then I'm sure we can help you figure that out.
Tue Aug 14, 2018 11:42 am
mundmc offline
I’m starting to get it, and THANK YOU, you nailed my lack of understanding on encoded dict entries.
Btw, my code was loaded with split() functions, running on strings taken from the dict. I think the split() functions may have been unhappy.
PS- This is all going towards a “switchboard” for the Dynamic Refreshing Image Plug-in, so different pages (for tablets in different rooms) can independently select their cameras to rotate displays.
Tue Aug 14, 2018 1:38 pm
split() should work with unicode strings the same way it works with non-unicode strings:
>>> es = u"3.2.4.56"
>>> es.split(".")
[u'3', u'2', u'4', u'56']
Tue Aug 14, 2018 1:43 pm
If you were using split() to break up dicts that were encoded into strings, you were doing it wrong. ;)
Tue Aug 14, 2018 1:53 pm
mundmc offline
(Laughing at work)
You could probably teach a CS elective of everything wrong I did writing this code!
Edit: FlyingDiver, I needed that. I am re-writing the whole thing using proper JSON!
What’s quicker? Reading from an Indigo Variable or from a local tex file (on an ssd)?
Tue Aug 14, 2018 3:23 pm
I doubt you'd notice any difference. The benefit to putting it into an Indigo variable is that you won't have to worry about the file getting moved, corrupt, etc.
If you do write it to a file, I highly recommend that you write it to the Plugin preferences directory so that the standard Indigo backup/restore/move process will maintain it:
my_cache_file_path = "{}/Preferences/Plugins/your.plugin.id.cache".format(indigo.server.getInstallFolderPath())
Use your plugin ID as a namespace to avoid name collisions.
Users browsing this forum: No registered users and 18 guests
