IF window close then.......
Thu Aug 09, 2018 10:20 am
koburg offline
Hi
since I never done a photon script before and I thing I need it here.
because else I need more triggers and the super condition plugin is no use in this example,
because it is not supporting the rfxcom plugin 100%
Device Window sensor
Device Somfy roller blind controlled from rfxcom.plugin
when I hit the down command for the roller blind I want to:
IF window is closed use the Somfy down command from rfxcom for the rollerblind all the way down.
But IF the window is open the I want the roller blind to execute the Somfy stop/my command from rfxcom.plugin instead.
anyone who can help me make a script to use in a trigger ?
Thu Aug 09, 2018 12:08 pm
Re: IF window close then.......
Doesn't sound like you actually need a script for this at all. But one question first - when you say "hit the down command", what are you actually doing? Pressing a button on a remote? Touching a button on a control page? Something else?
Thu Aug 09, 2018 2:24 pm
koburg offline
Yes I hit a button
Thu Aug 09, 2018 2:28 pm
koburg wrote:
Yes I hit a button
Control page or physical remote?
Thu Aug 09, 2018 2:33 pm
In any case, if you already have a trigger that fires when you push this button (whatever kind it is), then duplicate that trigger. In the first one, put a condition for the window being closed, then send the down command. In the second, put a condition for the window now closed, then send the My command.
