Unknown Error
Thu May 31, 2018 9:01 pm
ckeyes888 offline
Unknown Error
Been seeing this error today. No idea what it is...maybe a script somewhere?
 Error                           because embedded scripts execute sequentially they must complete their execution within 10 seconds.
   Error                           modify the script to exit quickly or convert it to an external file (not embedded).
   Stopping embedded script executor host (pid 1326)
   Script Error                    embedded script: <urlopen error [Errno 4] Interrupted system call>
     embedded script, line 9, at top level
     File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py", line 126, in urlopen
     File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py", line 394, in open
     File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py", line 412, in _open
     File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py", line 372, in _call_chain
     File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py", line 1199, in http_open
     File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py", line 1174, in do_open
URLError: <urlopen error [Errno 4] Interrupted system call>
Any ideas?
Carl
Thu May 31, 2018 9:30 pm
ckeyes888 offline
Re: Unknown Error
Think I found the script that's the problem.
#! /usr/bin/env python2.5
# -*- coding: utf-8 -*-
import simplejson
import urllib2
DTVIP = "192.168.1.53"
url = "http://%s:8080/tv/getTuned?" % DTVIP
f = urllib2.urlopen(url)
simplejson_string = f.read()
f.close()
parsed_simplejson = simplejson.loads(simplejson_string)
   programTitle = parsed_simplejson['title']
   indigo.variable.updateValue(1708209973, programTitle)
except:
   indigo.variable.updateValue(1708209973, " ")
   majorCh = str(parsed_simplejson['major'])
   indigo.variable.updateValue(564695813, majorCh)
except:
   indigo.variable.updateValue(564695813, " ")
Been using this script for quite some time without issue.
Any idea why it may have started to error?
edit: Something tells me this has something to do with why the FluxLED plugin fails as well.
Carl
Fri Jun 01, 2018 12:19 am
Re: Unknown Error
Can you open that URL manually in safari still to check it’s ok?
Fri Jun 01, 2018 9:21 am
Re: Unknown Error
[MODERATOR NOTE] moved to the Python Scripting forum since it's a Python script.
First, you should probably make this script an external script since it's making network calls which may take longer than 10 seconds to timeout and you don't specify a timeout in the script (default network timeouts are usually 30 seconds or more).
Second, I suspect that @howartp is pointing you in the right direction: it seems likely that the network service you're trying to talk to is either offline or otherwise hung up and isn't responding to the urlopen() call.
Fri Jun 01, 2018 9:39 pm
ckeyes888 offline
Re: Unknown Error
Tried resetting the IP address to something different, then back to where I had it originally and it worked again.
If I’m ever on life support and nothing’s working, unplug me...then plug me in again and see if that works.
Carl
Sat Jun 02, 2018 5:52 am
Re: Unknown Error
