Shell script / Python / Node / Newb lost ...
Mon Apr 23, 2018 9:05 pm
Re: Shell script / Python / Node / Newb lost ...
@howartp, you mean like this?
import subprocess
command = ["/Users/myriam/.nvm/versions/node/v9.11.1/bin/ps4-waker", "standby", "-t", "30000", "env=node"]
proc = subprocess.Popen(command, stdout=subprocess.PIPE, stderr=subprocess.PIPE)
out, err = proc.communicate()
indigo.server.log(u"command error: %s" % err)
or something akin to that....
Mon Apr 23, 2018 9:12 pm
No.
subprocess.popen(command, err=stdpipe, out=stdpipe, env=node, shell=true)
That’s the shrunk version of what I mean...
Mon Apr 23, 2018 9:28 pm
pmgendon offline
howartp wrote:
No.
you guys are machines!!
Here's the code I ran:
import subprocess
command = ["/Users/myriam/.nvm/versions/node/v9.11.1/bin/ps4-waker", "standby", "-t", "30000"]
proc = subprocess.Popen(command, stdout=subprocess.PIPE, stderr=subprocess.PIPE, env=node, shell=true)
Here's the error I'm now having:
Script Error embedded script: global name 'node' is not defined
embedded script, line 6, at top level
NameError: global name 'node' is not defined
Mon Apr 23, 2018 9:34 pm
import subprocess
command = "/usr/local/bin/ps4-waker standby -t 30000"
proc = subprocess.Popen(command, stdout=subprocess.PIPE, stderr=subprocess.PIPE, env=‘node’, shell=True)
I’m thinking this?
I’ve reverted command back to my second reply about [commands, like, this].
I’ve also set path back to /usr/local/bin as I think that’s how you originally ran it - the env node should automatically find the path to /Miriam/.../node/.... etc without hard coding it, I think.
Mon Apr 23, 2018 10:01 pm
pmgendon offline
howartp wrote:
import subprocess
I’m thinking this?
Getting a different error this time
Script Error embedded script: execve() arg 3 must be a mapping object
embedded script, line 5, at top level
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/subprocess.py", line 710, in __init__
errread, errwrite)
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/subprocess.py", line 1335, in _execute_child
raise child_exception
TypeError: execve() arg 3 must be a mapping object
Mon Apr 23, 2018 10:27 pm
pmgendon offline
let's complicate things a bit !!!
I did not have a /usr/bin/node folder. I created one and created a symlink to the /Users/myriam/.nvm/versions/node/v9.11.1/bin/.
I ran the code again and I'm now getting the following error:
Script command error: env: node: Permission denied
Tue Apr 24, 2018 12:21 am
You don’t need a usr/bin/node folder.
https://scriptingosx.com/2017/10/on-the-shebang/ is a good explanation of the shebang line, which explains env as a magic way of finding where node is installed.
Wed Apr 25, 2018 10:42 am
pmgendon offline
that was an interesting read. I went ahead and removed the symlink.
Now i'm back to this error:
errread, errwrite)
