Python code working outside of Indigo but not as Embedded
Mon Feb 19, 2018 9:35 am
Suncroft offline
I am new to python and I am currently trying to get Electric usage into an Indigo Variable via an existing python script which talks to my Loop energy monitor. This works fine when running from the host command line as follows:
Python 2.7.10 (default, Feb 7 2017, 00:08:15)
[GCC 4.2.1 Compatible Apple LLVM 8.0.0 (clang-800.0.34)] on darwin
Type "help", "copyright", "credits" or "license" for more information.
>>> import pyloopenergy
>>> import time
>>> elec_serial = 'xxxxxxxxxx';
>>> elec_secret = 'yyyyyyyyyy';
>>> le = pyloopenergy.LoopEnergy(elec_serial, elec_secret)
>>> print(le.electricity_useage)
1.284
But when I try to run the same via an Indigo embedded python script I get no errors but also no update to the variable, it just reads - no value -
import pyloopenergy
import time
le = LoopEnergy(elec_serial, elec_secret)
indigo.variable.updateValue(932431696, le.electricity_useage)
Any thoughts where I may be going wrong? If I replace le.electricity_useage in the variable update with a string then the variable updates with the string so the variable id is correct.
Mon Feb 19, 2018 9:43 am
Re: Python code working outside of Indigo but not as Embedde
I think variables are all strings when they're stored. Try:
indigo.variable.updateValue(932431696,str(le.electricity_useage))
Mon Feb 19, 2018 5:27 pm
Suncroft offline
Thanks Joe, I did already try that and just tried it again now. The only difference is that the Variable is now populated with 'None' rather than '-no value -'. I think that for some reason le.electricity_useage is returning back no value when run from within the Indigo embedded script. Any other thoughts appreciated.
Mon Feb 19, 2018 5:37 pm
Log the value you get:
indigo.server.log(u"le.electricity_useage = %f" % le.electricity_useage)
Also, you might want to check that you're getting a valid object (not None) returned by the call to LoopEnergy().
Mon Feb 19, 2018 7:02 pm
I noticed that in your shell implementation, you call:
But in your Indigo script, you call:
Try updating your embedded script with the former and see what you get.
Tue Feb 20, 2018 4:44 am
Suncroft offline
Hi Joe, unfortunately I get the error 'embedded script: a float is required' with that logging line. I had previously tried logging the output of le.electricity_useage with the line 'indigo.server.log(le.electricity_useage)' but just got an empty entry in the log as follows:
20 Feb 2018, 01:11:39
Script
I think le.electricity_useage is returning an empty string but don't understand why its not working when run as an embedded script. Unless Indigo does not support the full python enviroment? I am not sure how to debug it further from within Indigo
@Dave, thats for the info, I had been using 'le = pyloopenergy.LoopEnergy(elec_serial, elec_secret)' but when I cut and paste into this thread, at the time I had copied the python code for the pylon-energy module into my embedded script so was not needing to reference pyloopenergy. Anyway unfortunately neither work and I am back to importing the module and my code is as follows:
import pyloopenergy
import time
elec_serial = 'xxxxxxxx';
elec_secret = 'yyyyyyyy';
So to recap with this code I get no entry in the Indigo log and a value of 'none' in my variable.
Tue Feb 20, 2018 4:56 am
Please try running with this line in place of Joe's suggested log line:
indigo.server.log(str(type(le.electricity_useage))
Tue Feb 20, 2018 5:18 am
Suncroft offline
Hi Dave,
I get this in the Indigo log.
Script <type 'NoneType'>
So I guess pyloopenergy us returning an empty value right?
Thanks for the help so far
Tue Feb 20, 2018 6:42 am
It appears that the function you're calling is returning None, which in Python is an object that indicates no value (it's not the same as an empty string or the value False). This may be telling us that the function you're calling is being called correctly, but is returning the value None. Given that Indigo is not returning an ImportError, it appears that Indigo can see the library you're calling, but as a test, please open the Indigo Scripting Shell from the Plugins menu and enter the following command:
import pyloopenergy
If that returns without error, please enter each line of your script in turn and see what results you get.
EDIT:
p.s.: You'll need to be at your server machine or connected through screen sharing or another remote desktop client. This test won't work if you're connecting to the server with a remote Indigo client.
Tue Feb 20, 2018 7:29 am
Suncroft offline
So this is interesting it works when I run it via the plugin scripting shell as advised and the variable in indigo updates with the correct value.
Connected to Indigo Server v7.1.1, api v2.0 (localhost:1176)
>>> import pyloopenergy
>>> import time
>>> elec_serial = 'xxxxxxxxxxxxxxx';
>>> elec_secret = 'yyyyyyyyyyyyyy';
>>> indigo.server.log(str(type(le.electricity_useage)))
Would you know then why the same script does not work as an embedded python script?
Tue Feb 20, 2018 7:33 am
Are you sure your embedded script has this line:
and not this line:
Also, using code tags when posting Python code really helps to make it more readable.
Tue Feb 20, 2018 9:41 am
Suncroft offline
Yes I am sure I am using "le = pyloopenergy.LoopEnergy(elec_serial, elec_secret)" in the embedded python script. Here is a direct cut and paste of what I have
import pyloopenergy
import time
If I cut and paste the same code into the scripting shell it works fine.
Tue Feb 20, 2018 9:52 am
So, you're positive that both scripts are identical? Embedded scripts are run in the same environment as the scripting shell so I'm quite confused as to why it's returning different results.
Tue Feb 20, 2018 1:47 pm
Suncroft offline
Hi Jay, yes I am 100% sure both scripts are identical. If I cut and paste the script into the scripting shell it works, if I paste it into the embedded script it does not. I also tried executing the script as a file but same issue also. Not sure how to debug further exactly what is happening here.
Tue Feb 20, 2018 1:55 pm
What are you cutting and pasting from? There could be hidden characters that the embedded route doesn’t like.
