Applescript to Python
Sun Jun 11, 2017 3:38 pm
CraigM offline
I'm on a mission to convert all my Applescripts to Python. Could someone please show me how the following would read in Python.
set value of variable "Month" to (month of (current date)) as text
set value of variable "DayofWeek" to (weekday of (current date)) as text
These are being used as Conditions in Schedules
Sun Jun 11, 2017 4:31 pm
kwijibo007 offline
Re: Applescript to Python
I'm assuming you want the variables to be the name of the day e.g 'Monday' and the name of the month e.g June.
import datetime
now = datetime.datetime.now()
Month = now.strftime('%B')
DayofWeek = now.strftime('%A')
Good luck pythoning!
Sun Jun 11, 2017 7:23 pm
import datetime
Two more lines are needed to update the variables.
import datetime
indigo.variable.updateValue(314742858, Month)
indigo.variable.updateValue(1928699259, DayofWeek)
You'll need to change the numbers to the IDs of your variables.
Mon Jun 12, 2017 2:17 pm
CraigM offline
Almost there, but not exactly what I was looking for as I have two different schedules and this code seems to have combined them both into one.
How can I split this so that it resembles the two separate lines of code in the original post?
Mon Jun 12, 2017 6:07 pm
Is this what you're looking for?
import datetime
indigo.variable.updateValue(314742858, DayofWeek)
import datetime
ETA - forgot the variable update bit.
Mon Jun 12, 2017 9:41 pm
CraigM offline
Thanks to everyone for getting this to work BUT:
Can someone explain why the Applescript code went in the Schedule/Condition/if script returns true screen:
And the Python code goes in as a Server Action
import datetime
indigo.variable.updateValue(123456789, DayofWeek)
Tue Jun 13, 2017 3:42 am
I think Matt or Jay will have to answer the why. I haven't really dabbled too much with AppleScript, and forget that feature is even there. I find that I'm able to do everything I need using either Indigo's native controls or with Python (or both).
Tue Jun 13, 2017 9:37 am
import datetime
Well - the AppleScript you have above doesn't return True or False, so it really didn't belong in the Condition script box but rather would be more appropriate as a Server Action. The purpose of the Condition Script is to return either a True or False value that would then either allow the actions connected to the schedule to run or not based on the logic. Setting the value there is somewhat inappropriate since that's really not it's purpose.
The result, however, is basically the same.
Sun Mar 10, 2019 12:41 pm
indigobo offline
Hi All!
I know this is an old topic, but thought I'd ask anyway... Using python, what if I wanted the day name of tomorrow? In other words if today is Sunday then day+1 = Monday, day +2 = Tuesday, etc.
import datetime
tomorrowWeekday = indigo.server.getTime().date() + datetime.timedelta(days=1)
indigo.variable.updateValue(421598678, str(tomorrowWeekday))
This gives me the date of tomorrow but not the day name.
Sun Mar 10, 2019 3:13 pm
 tomorrowWeekday.strftime("%A")
