Scripting shell
Sat Apr 22, 2017 11:06 am
Asconasny offline
Scripting shell
when i try the scripting shell i get a error, and the shell window exits.
   Interactive Shell Error         Error in plugin execution InitializeMain:
  File "/Library/Application Support/Perceptive Automation/Indigo 7/IndigoPluginHost.app/Contents/PlugIns/plugin_base.py", line 26, in <module>
  File "/Library/Application Support/Perceptive Automation/Indigo 7/IndigoPluginHost.app/Contents/PlugIns/serial/__init__.py", line 13, in <module>
  File "/Library/Application Support/Perceptive Automation/Indigo 7/IndigoPluginHost.app/Contents/PlugIns/serial/serialutil.py", line 10, in <module>
  File "/usr/local/Cellar/python/2.7.11/Frameworks/Python.framework/Versions/2.7/lib/python2.7/io.py", line 51, in <module>
ImportError: dlopen(/usr/local/Cellar/python/2.7.11/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload/_io.so, 2): Symbol not found: __PyCodecInfo_GetIncrementalDecoder
  Referenced from: /usr/local/Cellar/python/2.7.11/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload/_io.so
  Expected in: flat namespace
 in /usr/local/Cellar/python/2.7.11/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload/_io.so
anyone know how to fix this?
Sat Apr 22, 2017 11:09 am
Re: Scripting shell
Delete your homebrew Python install.
Sat Apr 22, 2017 11:57 am
Asconasny offline
Re: Scripting shell
jepp, that worked!
I dont even remember why or when i installed python via homebrew.
Thank you
