External script can't see the change on the onState property
Tue Dec 27, 2016 5:23 pm
Turribeach offline
I want to execute a while loop while a device it's on. I got this code in an external Python script:
ToiletLight = indigo.devices[999999999]
while ToiletLight.onState and ToiletLight.enabled:
   do something
The script works as expected in that if the device it's Off it won't go inside the while loop and if it is On it will get inside and execute what I want. But the issue I got is that if I switch the device off while the while loop it's executing it the script never exits the while loop even though ToiletLight.onState should then be False. I have printed the ToiletLight.onState inside the while statement and I can confirm it stays True, at least for context of this script. Am I doing something wrong? Why can't the external script see the change on the ToiletLight.onState property value?
Tue Dec 27, 2016 9:22 pm
Re: External script can't see the change on the onState prop
is returning a static snapshot of the device state. You either need to re-fetch it or update it inside the loop.
Wed Dec 28, 2016 3:54 am
Turribeach offline
Thanks Joe, that works. I was incorrectly assuming the line was returning a reference to the object, not a copy. Here is how it looks now:
   do something
Wed Dec 28, 2016 2:12 pm
The efficiency is about identical, but you can also just do:
ToiletLight. refreshFromServer()
Wed Dec 28, 2016 6:33 pm
Turribeach offline
Thanks Matt. I have now changed it as it is a lot more clearer using refreshFromServer().
