How to change logging category?
Sun Dec 18, 2016 6:28 pm
ryanbuckner offline
In python, how do I change the category when logging?
For example, this developer set it to "Alexa-Hue Bridge"
   Alexa-Hue Bridge                + Publishing device 'Master Bathroom Lights' to Alexa
   Alexa-Hue Bridge                + Publishing device 'Play Room Lights' to Alexa
   Alexa-Hue Bridge                + Publishing device 'TV Lights' to Alexa
   Alexa-Hue Bridge                + Publishing device 'Television' to Alexa
Mon Dec 19, 2016 12:15 pm
Re: How to change logging category?
Anything a plugin writes to the Indigo log will automatically get the name of the plugin as the log type.
You can, however, use the type argument to the log method to set it to something else:
indigo.server.log("Text to log", type="Some Type")
Mon Dec 19, 2016 4:21 pm
ryanbuckner offline
Thanks Jay
Fri Dec 23, 2016 10:13 am
ryanbuckner offline
 Script Error                    bmwpostv1.py: invalid syntax
   Script Error                    around line 26 - "indigo.server.log(status, type=“BMW Plugin”)"
Looks like that throws an error
Here's the code:
indigo.server.log(u"Executing " + service)
resp = c.executeService(vin, service)
status = resp['executionStatus']['status']
while status in ('INITIATED','PENDING'):
    if sendStatus:
        indigo.server.log(status, type="BMW Plugin")
        sendStatus = False
    time.sleep(5)
    check = c.call('/user/vehicles/{}/serviceExecutionStatus?serviceType={}'.format(vin, service))
    status = check['executionStatus']['status']
Fri Dec 23, 2016 11:06 am
Have you mixed up tabs and spaces for your indents, that will cause a problem if you have.
The indigo log statement looks OK to me. :)
Fri Dec 23, 2016 3:01 pm
It appears, from the error statement, that you're using fancy quotes, not simple double quotes. Check that.
Fri Dec 23, 2016 3:06 pm
Your eyesight is obviously better than mine :shock: - well spotted! :)
Fri Dec 23, 2016 3:07 pm
Been bit by that way too many times. Finally figured out what was causing it. Some weird interaction with international keyboard input when I had both US and GB keyboards enabled on my iMac.
Fri Dec 23, 2016 6:45 pm
ryanbuckner offline
That was it. Thanks ! !
Users browsing this forum: brettlid and 6 guests
