dz1rfj wrote:more about a virtual device that speaks.
Here is the 'How To' with Virtual Devices
http://wiki.indigodomo.com/doku.php?id=plugins:devicecollectionSince you can't add an Action as a device to Alexa.... You create a Virtual device. You will need to create the backbone to each virtual device. (Actions and a Variable) An action for when the virtual device turns on, one for off and one for toggle. Then you can even create a variable for your new Virtual Device to track it's state.
The remainder is done with new actions. You can add any action... turn on crap, etc.... but at the bottom of the Edit Action Group, I use "Speak: Alexa,, Play Metallica" and that is my On command. I needed two commas after Alexa to give her an extra second to pay attention.
It works... lots of room for error. Guy is outside my office mowing right now so I had to execute the command three times for her to hear it correctly. But usually it works fine. It is a little weird having devices talking to each other... like with actual words. Fast forward a year from now and I will probably walk in on an argument between tech devices.
The problem is naming the Virtual Device so it doesn't confuse Alexa when you verbally give the command to another Alexa Device. If I name the Virtual Device "Play Metallica" and I tell my living room Echo "Play Metallic On".... it will just play Metallica in that room. So I called it "Airfoil". So my verbal command to Living room Echo is "Turn Airfoil On" (Which then turns 'On' the Virtual Device which runs the "Airfoil On" Action Group which Switches Source to Input, Turn on Airfoil Speakers, Speak "Alexa,, Play Metallica".
As long as the Dot is close enough to hear the itty-bitty MacMini speaker.... it should work for you.
I hope someone writes a Amazon Skill that allows you to control one Alexa device from another. But this lets me sorta do it until then.
