Simple scripting question
Wed Oct 12, 2016 10:56 am
trevorsmith offline
During a scheduled evetn I am calling a script in an external file. This works fine, but in that file I wish to execute a script in another external file (in the same folder as the original), so this (in principle) is what I wish to do
file1.py:
#set a variable or some other python code
indigo.variables[blah blah].....
#now call another script in file2.py
execfile("file2.py")
file2.py:
#do whatever is required!.....
How do I make it work? I get an error stating file2.py doesnt exist
Wed Oct 12, 2016 11:13 am
Re: Simple scripting question
Can you provide a little bit more information on what you want to accomplish? For example, are you passing information from script 1 to script 2? Does script 2 need to wait for script 1 to finish before executing?
The solution may be simpler than you think.
Wed Oct 12, 2016 11:18 am
trevorsmith offline
Thanks. I basically wish to use some code in file2 within file1, so file2 should execute then file1 should continue. Basically calling a function within file2
Wed Oct 12, 2016 11:30 am
Put the code in file2.py into a function, then import that function in file1 and use it:
from file2 import myFunction
myFunction(params)
Wed Oct 12, 2016 12:23 pm
trevorsmith offline
thank you
