Variable Use
Sat Aug 20, 2016 6:16 am
cramer offline
Variable Use
I have defined a Virtual on/off device which assigns the onOffState to a variable - 'homeActive'. A Python script file is actioned in an action group assigned to the device
Is the variable automatically created as a result of this assignment?
How should the variable be referenced within the script file?
A newbie Python question, how is the entry point into the Python script declared at which the script will start when called by the server?
Sat Aug 20, 2016 6:25 am
Re: Variable Use
You can create an Indigo variable (which is not the same as a Python variable) in a script, but it's not done by default. Do it manually before you run the script.
To change the value of the Indigo variable, you would do something like:
indigo.variable.updateValue(1766478875, str(datetime.datetime.now()))
Python scripts called from Indigo start at the beginning of the script. There's no defined entry point.
Sat Aug 20, 2016 6:31 am
cramer offline
Re: Variable Use
How / where do I create the Indigo variable so that it exists before the action group associated with the on/off device that references the variable is actioned?
Sat Aug 20, 2016 6:33 am
Re: Variable Use
In the Variable List window. cmd-9 in Indigo.
Sat Aug 20, 2016 6:38 am
cramer offline
Re: Variable Use
Got it. Thanks.
Sat Aug 20, 2016 11:32 am
Re: Variable Use
I prefer to create most variables and variable folders programmatically so that in the outside chance that one gets deleted, my scripts will still work. Here's a snippet which shows the syntax:
# Create folders or variables if they have been somehow deleted.
if 'folder_name' not in indigo.variables.folders:
    indigo.variables.folder.create('folder_name')
if 'var_name' not in indigo.variables:
    indigo.variable.create('var_name', 'var_value', folder=folder_name)
Replace folder_name, var_name, and var_value with the appropriate values. Note that var_value must be a string because Indigo stores all variable values as strings.
http://wiki.indigodomo.com/doku.php?id=indigo_6_documentation:plugin_scripting_tutorial#variable_examples
Dave
