State variable not updating
Fri Aug 12, 2016 5:14 pm
nlagaros offline
What am I doing wrong here? I have the script below that is called in an action. The z1v variable does not update even though the volume is adjusting appropriately. I see it in the GUI state list. For some reason the variable is only populated correctly the first time. Once in the loop, it just keeps the initial value.
z1v = int(dev.states['zone1volume'])
while z1v != -30:
   indigo.server.log("z1v: %s" % z1v)
   if z1v < -30:
      PioneerPlugin.executeAction("zone1volumeUp", deviceId=PioneerFR)
      PioneerPlugin.executeAction("zone1volumeDown", deviceId=PioneerFR)
Fri Aug 12, 2016 6:00 pm
Re: State variable not updating
Is z1v an Indigo variable? Not a local one for the script? If so, you need to push the updated value back to the server:
indigo.variable.updateValue("z1v", int(dev.states['zone1volume']))
I think that's right. I use the Variable ID in my scripts, not the names.
Fri Aug 12, 2016 6:28 pm
nlagaros offline
z1v is just a local variable that I created for the loop.
Fri Aug 12, 2016 6:51 pm
I think dev is a snapshot from when the script is started. If you want updated values there's an api call to get the current values.
Sat Aug 13, 2016 5:09 am
nlagaros offline
Thanks for the tip. I can re-address the device to get the updated value.
Sat Aug 13, 2016 6:23 am
Colorado4Wheeler offline
Try changing that last line to:
z1v = int(indigo.devices[12345].states['zone1volume'])
And see if that helps. There are actual official ways to refresh but that is just as effective since you are pulling the item right from the Indigo collection again.
Sat Aug 13, 2016 11:21 am
The dev instance is a cached copy. Use dev.refreshFromServer() to have the copy refreshed.
Sat Aug 13, 2016 4:21 pm
nlagaros offline
