Is this the error you're getting?
- Code: Select all
Command "python setup.py egg_info" failed with error code 1 in /private/tmp/pip-build-MixvQi/pandas/
If so, I think it's a problem with the pandas installer itself. I'm getting the same error, even though I've had no problem installing other packages on El Capitan. Try installing requests or twilio or django and see if you have a problem with other packages:
- Code: Select all
Shamu:Season 2 jkeenan$ sudo pip install twilio
DEPRECATION: Python 2.6 is no longer supported by the Python core team, please upgrade your Python. A future version of pip will drop support for Python 2.6
The directory '/Users/jkeenan/Library/Caches/pip/http' or its parent directory is not owned by the current user and the cache has been disabled. Please check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag.
The directory '/Users/jkeenan/Library/Caches/pip' or its parent directory is not owned by the current user and caching wheels has been disabled. check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag.
Collecting twilio
/Library/Python/2.6/site-packages/pip-8.1.2-py2.6.egg/pip/_vendor/requests/packages/urllib3/util/ssl_.py:318: SNIMissingWarning: An HTTPS request has been made, but the SNI (Subject Name Indication) extension to TLS is not available on this platform. This may cause the server to present an incorrect TLS certificate, which can cause validation failures. You can upgrade to a newer version of Python to solve this. For more information, see https://urllib3.readthedocs.org/en/latest/security.html#snimissingwarning.
SNIMissingWarning
/Library/Python/2.6/site-packages/pip-8.1.2-py2.6.egg/pip/_vendor/requests/packages/urllib3/util/ssl_.py:122: InsecurePlatformWarning: A true SSLContext object is not available. This prevents urllib3 from configuring SSL appropriately and may cause certain SSL connections to fail. You can upgrade to a newer version of Python to solve this. For more information, see https://urllib3.readthedocs.org/en/latest/security.html#insecureplatformwarning.
Downloading twilio-5.4.0.tar.gz (193kB)
100% |████████████████████████████████| 194kB 2.9MB/s
Requirement already satisfied (use --upgrade to upgrade): httplib2>=0.7 in /Library/Python/2.6/site-packages (from twilio)
Requirement already satisfied (use --upgrade to upgrade): six in /Library/Python/2.6/site-packages (from twilio)
Requirement already satisfied (use --upgrade to upgrade): pytz in /System/Library/Frameworks/Python.framework/Versions/2.6/Extras/lib/python (from twilio)
Installing collected packages: twilio
Running setup.py install for twilio ... done
Successfully installed twilio-5.4.0
Also, looking at the info page for the pandas project, I think it may require Python 2.7.
Yup. I was able to install it for 2.7:
- Code: Select all
Shamu:Season 2 jkeenan$ sudo pip2.7 install pandas
Collecting pandas
Downloading pandas-0.18.1-cp27-cp27m-macosx_10_6_intel.macosx_10_9_intel.macosx_10_9_x86_64.macosx_10_10_intel.macosx_10_10_x86_64.whl (10.0MB)
100% |████████████████████████████████| 10.0MB 160kB/s
Requirement already satisfied (use --upgrade to upgrade): pytz>=2011k in /System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python (from pandas)
Requirement already satisfied (use --upgrade to upgrade): python-dateutil in /System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python (from pandas)
Requirement already satisfied (use --upgrade to upgrade): numpy>=1.7.0 in /System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python (from pandas)
Installing collected packages: pandas
Successfully installed pandas-0.18.1
