Energy consumption script
Sun Jun 26, 2016 6:30 am
Asconasny offline
Hi
I have a A/C unit connected to a Fibaro plug and i would like know the daily, yesterday, weekly ,monthly and if possible yearly energy consumption.
I belive a script would be the best option which would calculate and feed the numbers into variables so i could use it on a control page.
Anyone made something similar to this and want to share so i can get some pointers? :)
regards
Asconasny
Sun Jun 26, 2016 7:22 am
Re: Energy consumption script
Wrote this some time ago. works for my energy meters.
this is my input device and state. It uses the "accumulated energy" state
dEnergy = "MeterTotalLeftBox" # this is the device name from where we read the energy info
dEnergyState = "accumEnergyTotal" # this is the state name of the device we read
if your also delivers energy total you only need to change the devices name and state in the script and run it every 1/5/10/.. minutes (up to you how often probably 10 is fine)
## if you reset your energy device at midnight, this must run AFTER the reset, call from a schedule at 0:01 + every x minutes
## calculates:
#   1. energy consumed yesterday
#   2. energy consumed today
#   3. energy consumption prediction for today, linear extrapolation from #2 and seconds since midnight
## name or id of your energy device name with "";  id just the number not quotes
## define your variable names here, the default should work fine
vEnergyYesterday      = "EnergyYesterday"        # this is the name of the variable that shows the KwH consumed yesterday
vEnergyToday          = "EnergyToday"          # this is the name of the variable that shows todays current engery consumed in KwH
vEnergyTodayPredicted    = "EnergyTodayPredicted" # this is the name of the variable that shows todays predicted total engery consumed in KwH
vEnergyDayNumber      = "EnergyDayNumber"      # this is the name of the variable that is used to keep track if we have calculated yesterdays consumption. it is the day in the month number
vEnergyMonth         = "EnergyMonth"          # this is the name of the variable that is used energy consumed this month
vEnergyDay            = "EnergyDay"            # this is the name of the variables that is used for Day_1, Day_2...
vEnergyHiddenN         = "EnergyHiddenN"        # this is the name of the variable that is used to keep track of hidden numbers
########### constants
daysInHours=4
daysInDays = 10
## import libraries
import simplejson as json
import datetime
# get dates and seconds
rightNow          = datetime.datetime.now()
secondsSinceMidnight = (rightNow.hour * 3600) + (rightNow.minute * 60) + rightNow.second
secondsInAday       = float(60*60*24)
## get the values and if the variables dont exits, create them
try:     xxx= indigo.variables[vEnergyYesterday]
except:  indigo.variable.create(vEnergyYesterday,"0")
try:    xxx = indigo.variables[vEnergyTodayPredicted]
except: indigo.variable.create(vEnergyTodayPredicted,"0")
try:    xxx = indigo.variables[vEnergyToday]
except: indigo.variable.create(vEnergyToday,"0")
try:    xxx = indigo.variables[vEnergyMonth]
except: indigo.variable.create(vEnergyMonth,"0")
try:    xxx = indigo.variables[vEnergyDay+"_1"]
except:
   indigo.variable.create(vEnergyDay+"_1","0")
   indigo.variable.create(vEnergyDay+"_2","0")
   indigo.variable.create(vEnergyDay+"_3","0")
   indigo.variable.create(vEnergyDay+"_4","0")
   indigo.variable.create(vEnergyDay+"_5","0")
   indigo.variable.create(vEnergyDay+"_6","0")
   indigo.variable.create(vEnergyDay+"_7","0")
   indigo.variable.create(vEnergyDay+"_8","0")
   indigo.variable.create(vEnergyDay+"_9","0")
try:     xxx= indigo.variables[vEnergyHiddenN]
except:   indigo.variable.create(vEnergyHiddenN,json.dumps({"theDay":-1, "dayV":[ [0,0,0] for i in range(daysInDays)],"theHour":-1, "hourV":[  [  [0,0,0] for k in range(24)  ] for i in range(daysInHours)] ,"monthRaw":0}))
####################                                 current day#          #ofM,maxV,rawV for daysInDays days    current hour#        #ofM,maxV,rawV  for 24 hours for 3 days day=0 = today   raw number from beginning of month
## read new energy
energyNow         = float(indigo.devices[dEnergy].states[dEnergyState]) #  this is the new raw number from the device
EnergyHiddenN = json.loads(indigo.variables[vEnergyHiddenN].value)
# now calculate
if EnergyHiddenN["theHour"] != rightNow.hour:
    EnergyHiddenN["theHour"] = rightNow.hour
    if EnergyHiddenN["theDay"] != rightNow.day:   # if this is a new day, update yesterdays value
        EnergyHiddenN["theDay"] = rightNow.day
        indigo.variable.updateValue(vEnergyYesterday   , ("%6.1f"%(energyNow - EnergyHiddenN["dayV"][0][2])).strip(" "))
        del EnergyHiddenN["dayV"][daysInDays-1]
        EnergyHiddenN["dayV"] =[[0,0,energyNow]]+EnergyHiddenN["dayV"]# copy the last raw value and reset number of M and measurement from yesterday
        for ii in range(1,daysInDays):
            indigo.variable.updateValue(vEnergyDay+"_"+str(ii), ("%6.1f"%(EnergyHiddenN["dayV"][ii][1])) )
        if energyNow < EnergyHiddenN["dayV"][1][2]: # need to reset?  works if reset happens at midnight, if it hapens during the day this is wrong, but you can only take care of some many variations ;-(
            EnergyHiddenN["dayV"][0][2]=0
        del EnergyHiddenN["hourV"][daysInHours-1]
        EnergyHiddenN["hourV"] =[[[0,0,0] for k in range(24)]]+EnergyHiddenN["hourV"]# copy the last raw value and reset number of M and measurement
        if rightNow.day ==1:
         EnergyHiddenN["monthRaw"] =  energyNow
    EnergyHiddenN["hourV"][0][rightNow.hour][2]= energyNow
EnergyHiddenN["dayV"][0][0]  +=1
EnergyHiddenN["dayV"][0][1]   = energyNow -  EnergyHiddenN["dayV"][0][2]
EnergyHiddenN["hourV"][0][rightNow.hour][0] +=1
EnergyHiddenN["hourV"][0][rightNow.hour][1]  = energyNow -  EnergyHiddenN["hourV"][0][rightNow.hour][2]
avHourLastdays=[0. for i in range(24)]
t=0
av=0
an=0
for i in range(24):
   n=0
   t=0.
   a=0
   if EnergyHiddenN["hourV"][1][i][0] >0:
      a += EnergyHiddenN["hourV"][1][i][1]
      n+=1
      av+=EnergyHiddenN["hourV"][1][i][1]
      an+=1
   if EnergyHiddenN["hourV"][2][i][0] >0:
      a += EnergyHiddenN["hourV"][2][i][1]
      n+=1
      av+=EnergyHiddenN["hourV"][2][i][1]
      an+=1
   avHourLastdays[i]= a/max(1.0,n)
   t+=a
total= max(t,1.)
average= av/max(1.,an)
w= total
for i in range(rightNow.hour):
   w+=EnergyHiddenN["hourV"][0][i][1] * average /(max(1.,avHourLastdays[i]) )
w+= EnergyHiddenN["hourV"][0][rightNow.hour][1]   *   ( 60./(max(1.,rightNow.minute)) )   *   ( average /(max(1.,avHourLastdays[rightNow.hour])) )
EnergyTodayPredicted =w* secondsSinceMidnight/(3600.*24)
#indigo.server.log("dayV      "+ json.dumps( EnergyHiddenN["dayV"][0] )  )
EnergyToday   = energyNow - EnergyHiddenN["dayV"][0][2]
EnergyMonth   = energyNow - EnergyHiddenN["monthRaw"]
indigo.variable.updateValue(vEnergyHiddenN, json.dumps(EnergyHiddenN))
#indigo.server.log("EnergyHiddenN         "+ json.dumps(EnergyHiddenN, indent=4))
#EnergyTodayPredicted    = EnergyToday * secondsInAday/max(secondsSinceMidnight,1.)
#EnergyTodayPredicted    = ((lastE)+ (EnergyToday-lastE)* 60./max(rightNow.second,1.)) *max( EH[0][23][1],  EH[0][[1])/(max( EH[1],1))
indigo.variable.updateValue(vEnergyToday,          ("%6.1f"%EnergyToday).strip(" "))
#indigo.variable.updateValue(vEnergyTodayPredicted, ("%6.1f"%EnergyTodayPredicted).strip(" "))
#indigo.server.log("rightNow             "+str(rightNow))
#indigo.server.log("rightNow.day               "+str(rightNow.day))
#indigo.server.log("secondsSinceMidnight "+str(secondsSinceMidnight))
#indigo.server.log("EnergyToday          "+str(EnergyToday))
#indigo.server.log("EnergyTodayPredicted "+str(EnergyTodayPredicted))
Sun Jun 26, 2016 7:32 am
Asconasny offline
Sweet!
Will try it out asap :)
Regards
Asconasny
Thu Jun 30, 2016 5:09 pm
you could also try this:
http://forums.indigodomo.com/viewtopic.php?f=188&t=15241
it creates variable with min/max/ave for
hour//lasthour/day/lastday/thisweek/lastweek/this month/lastmonth
you could use average and multiply with time, then you have your consumption.
eg ave consumption was 5kw for 1 week then multiply with 24*7 and you have kwh = 168*5 = 840kwh
