Python extreme novice, seeks guidance on a "requests" issue
Tue May 10, 2016 7:00 am
mat offline
Good afternoon.
Im seeking a little guidance, or help on the following. Apparently its a fairly simple issue, but Im struggling.
I'm trying to control my Viera Panasonic TV, and if I can get the basic code working, will look to construct what I hope is a simple plugin. I just cant get the python to work.
I have the following xml data that is posted with headers to the TV.
XML
<?xml version"1.0" encoding="utf-8"?>
<s:Envelope xmlns:s="http://schemas.xmlso.../soap/envelope/" s:encodingStyle="http://schemas.xmlso.../soap/encoding/">
<s:Body>
<u:X_SendKey xmlns:u="urn:panasonic-com:service:p00NetworkControl:1">
<X_KeyEvent>NRC_MUTE-ONOFF</X_KeyEvent>
</u:X_SendKey>
</s:Body>
</s:Envelope>
Header
Accept: text/xml
Cache-Control: no-cache
Pragma: no-cache
Content-Type: text/xml;charset="utf-8"
SOAPACTION: "urn:panasonic-com:service:p00NetworkControl:1#X_SendKey\"
Content-Length:324
Posted 'to' (http://192.168.1.55:55000/nrc/control_0)
Now, I can get this to work from Cromes Postman app all well and good, and can send any of the commands needed to control the TV.
The Postman app generates the python code below, which requires the 'requests' module, which I have confirmed is installed for python 2.6. However, when I run the code below on the same machine as Postman (or any other computer), I get a 400 error from the TV. I've tried a script within indigo and from PyCharm.
I've been looking at this for a week or so, and would be grateful for some guidance please. Thanks.
import requests
url = "http://192.168.1.55:55000/nrc/control_0"
payload = "<?xml version\"1.0\" encoding=\"utf-8\"?>\n<s:Envelope xmlns:s=\"http://schemas.xmlso.../soap/envelope/\" s:encodingStyle=\"http://schemas.xmlso.../soap/encoding/\">\n<s:Body>\n<u:X_SendKey xmlns:u=\"urn:panasonic-com:service:p00NetworkControl:1\">\n<X_KeyEvent>NRC_MUTE-ONOFF</X_KeyEvent>\n</u:X_SendKey>\n</s:Body>\n</s:Envelope>"
headers = {
    'accept': "text/xml",
    'cache-control': "no-cache",
    'pragma': "no-cache",
    'content-type': "text/xml;charset=\"utf-8\"",
    'soapaction': "\"urnpanasonic-comservicep00NetworkControl1#X_SendKey\\"",
    'content-length': "324",
    'postman-token': "e17a5e11-b628-faa7-cac3-7391c01d8c0f"
response = requests.request("POST", url, data=payload, headers=headers)
print(response.text)
Late 2018 mini 10.14
Tue May 10, 2016 11:10 am
Re: Python extreme novice, seeks guidance on a "requests" is
It looks like the length is incorrect. You should calculate the lengh:
import requests
payload = u"<?xml version\"1.0\" encoding=\"utf-8\"?>\n<s:Envelope xmlns:s=\"http://schemas.xmlso.../soap/envelope/\" s:encodingStyle=\"http://schemas.xmlso.../soap/encoding/\">\n<s:Body>\n<u:X_SendKey xmlns:u=\"urn:panasonic-com:service:p00NetworkControl:1\">\n<X_KeyEvent>NRC_MUTE-ONOFF</X_KeyEvent>\n</u:X_SendKey>\n</s:Body>\n</s:Envelope>"
headers = {
    'content-length': len(payload),
Tue May 10, 2016 1:10 pm
mat offline
Thanks Jay, I had recreated code in the office. point taken on calculating len.
Using code below with the length addition from plugin menu items, and its not working.
Event log is showing
Example Device - Custom Debug startup called
Script Starting new HTTP connection (1): 192.168.1.55
Not working from within Pycharm either, which is returning with "process finished with exit code 0", and response =400
import requests
url = "http://192.168.1.55:55000/nrc/control_0/"
payload = "<?xml version=\"1.0\" encoding=\"utf-8\"?>\n<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n<s:Body>\n<u:X_SendKey xmlns:u=\"urn:panasonic-com:service:p00NetworkControl:1\">\n<X_KeyEvent>NRC_POWER-ONOFF</X_KeyEvent>\n</u:X_SendKey>\n</s:Body>\n</s:Envelope>"
headers = {
    'soapaction': "\"urnpanasonic-comservicep00NetworkControl1#X_SendKey\"",
    'content-type': "application/xml",
    'postman-token': "2784b484-ac90-5eb4-8895-f93d98d4e86e"
Wed May 11, 2016 4:42 pm
Sorry - the server just isn't accepting the message for some reason. I don't know why. Try this:
import requests
payload = '''<?xml version"1.0" encoding="utf-8"?>
<s:Body>
</u:X_SendKey>
</s:Body>
</s:Envelope>'''
headers = {
Just in case the string is getting munged. If that doesn't work, then try adding a carriage return before the final ''' in case the message has to end with a line feed. Pretty sad that the destination system doesn't give you any clues other than a 400 error... :roll:
Thu May 12, 2016 2:09 pm
mat offline
Thanks Jay.
Tried both those options earlier and neither worked unfortunately.
I have however found a github project https://github.com/tomokas/pyviera that I am going to attempt to work into a plugin (theres no licence info though, so have emailed the author). I've got the script loaded up on my laptop and it runs perfectly, controlling all 4 tv's independently. It should control all panasonic TV's from around 2012 so hopefully will be of use to some if the guy confirms I can use a good proportion of his code. It may well work with panasonic b/r players and hard drive recorders too. I have one that i can test on so will confirm.
Thanks for you persistence as always. I may well be asking the community for pointers on the plugin soon!
Mat
