- Posted on
Thu Apr 28, 2016 1:45 pm
Different Computers
offline
I'm trying to make the remote computer run a command line tool called imagesnap, which takes a picture. And I'm saving it to the drop box on the indigo server.
but the error I'm getting when I try to run the python command suggests that the problem is with
- Code: Select all
commands.getstatusoutput
rather than with the ssh.
I'm afraid I don't understand this next bit at all:
- Code: Select all
xxx= commands.....
Then check xxx.
If xxx=="whatever": indigo.server.log(" ok")
