Indigo variables example
Fri Jan 15, 2016 9:24 am
skoeppen offline
I'm just learning Python scripting in Indigo. The code below was run in the scripting shell and is essentially the first example given in the Indigo scripting tutorial on variables. Why doesn't newVar.value show the updated values?
>>> newVar = indigo.variable.create("fooMonster", "5")
>>> newVar.value
u'5'
>>> indigo.variable.updateValue(newVar, "10")
>>> newVar.value
u'5'
>>> indigo.variable.updateValue(newVar, "20")
>>> newVar.value
u'5'
Steve Koeppen
X10 user from the early 80's
Converted to Insteon 2011 - 2014
Started adding z-wave 2014
Happy :D Indigo owner since v1 in 2005
Fri Jan 15, 2016 9:47 am
Re: Indigo variables example
You need to do a refresh after the update to refresh the local copy as per the Variable Class documentation
Add this line after you do each update value:
newVar.refreshFromServer()  # refresh needed to update local's .value
Hope this helps :)
Fri Jan 15, 2016 10:22 am
skoeppen offline
Thanks Jon. That did it.
Steve Koeppen
