Parrot Flower Power - Web API
Sat Apr 30, 2016 1:09 pm
Different Computers offline
Re: Parrot Flower Power - Web API
Now I need to see if I can afford some of these Parrots!
Could some kind soul look at this example above and tell me whether it would be a good model for trying to make the BloomSky weather station APIwork with Indigo? I'm willing to poke at it if this framework could be repurposed for it.
Mon May 02, 2016 5:04 am
Mirko offline
Hi Matt,
To be honest I do not know how to install this part: Requests.
I opened copy/paste it in Smultron and I saved it.
Maybe you can help me out here.
Mirko
Mon May 02, 2016 5:49 am
Open the Terminal application an d copy/paste in:
curl -O https://bootstrap.pypa.io/get-pip.py
sudo python2.6 get-pip.py
sudo pip requests
Mon May 02, 2016 10:11 am
Mirko offline
Hi Matt,
I get
sudo pip requestsminiserver:~ admin$ curl -O https://bootstrap.pypa.io/get-pip.py
sudo pip requests
curl: (35) Unknown SSL protocol error in connection to bootstrap.pypa.io:443
miniserver:~ admin$ sudo python2.6 get-pip.py
Password:
python2.6: can't open file 'get-pip.py': [Errno 2] No such file or directory
miniserver:~ admin$
This is on my MacMiniserver 10.6.8
Do you know what I should do next?
Regards,
Mirko
Tue May 03, 2016 3:42 pm
In the curl lines replace "https" with "http" and I believe it will work around the problem/error you are seeing.
Wed May 04, 2016 3:25 am
Mirko offline
Now I get (without having been able to change 'https' into 'http')
DEPRECATION: Python 2.6 is no longer supported by the Python core team, please upgrade your Python. A future version of pip will drop support for Python 2.6
The directory '/Users/admin/Library/Caches/pip/http' or its parent directory is not owned by the current user and the cache has been disabled. Please check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag.
The directory '/Users/admin/Library/Caches/pip' or its parent directory is not owned by the current user and caching wheels has been disabled. check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag.
/tmp/tmpNfmAhU/pip.zip/pip/_vendor/requests/packages/urllib3/util/ssl_.py:315: SNIMissingWarning: An HTTPS request has been made, but the SNI (Subject Name Indication) extension to TLS is not available on this platform. This may cause the server to present an incorrect TLS certificate, which can cause validation failures. For more information, see https://urllib3.readthedocs.org/en/late ... ingwarning.
/tmp/tmpNfmAhU/pip.zip/pip/_vendor/requests/packages/urllib3/util/ssl_.py:120: InsecurePlatformWarning: A true SSLContext object is not available. This prevents urllib3 from configuring SSL appropriately and may cause certain SSL connections to fail. For more information, see https://urllib3.readthedocs.org/en/late ... ormwarning.
Requirement already up-to-date: pip in /Library/Python/2.6/site-packages
Sat May 07, 2016 10:20 am
PME999 offline
Hello
I have exactly the same message from the terminal .
I'm am very interested in any solution
Thanks a lot
Patrice
