[solved] Calculate if today or tomorrow is a holiday
Fri Apr 03, 2015 4:27 am
Nine offline
I'm trying to check if today is a holiday to set a variable to true. For that I use the following python-script to detect:
#! /usr/bin/env python2.5
# -*- coding: utf-8 -*-
# Check if today is a holiday and return true
# Autor: Simon Betschmann
# Version: 1.0
# Date: 03.04.2015
import datetime
from datetime import date
today = date.today()
tomorrow = today + datetime.timedelta(days=1)
def holidays(year):
 # reset the variable
 indigo.variable.updateValue(208372369, value="false") # "Feiertag_heute"
 indigo.variable.updateValue(857228602, value="false") # "Feiertag_morgen"
 indigo.variable.updateValue(671348986, value="") # "Feiertag_heute_text"
 indigo.variable.updateValue(1181470489, value="") # "Feiertag_morgen_text"
 hl = Holidays(year)
 holidays = hl.get_holiday_list()
 for h in holidays:
    print h[0]
    if today == h[0]:
        indigo.server.log(u'Today is a holiday: '+ h[1])
        indigo.variable.updateValue(208372369, value="true") # "Feiertag_heute"
        indigo.variable.updateValue(671348986, value=h[1])   # "Feiertag_heute_text"
    if tomorrow == h[0]:
        indigo.variable.updateValue(857228602, value="true") # "Feiertag_morgen"
        indigo.variable.updateValue(1181470489, value=h[1])   # "Feiertag_morgen_text"
class Holidays:
 def __init__(self, year):
     self.year = int(year)
     easter_day = EasterDay(self.year)
     self.easter_date = easter_day.get_date()
     self.holiday_list = []
     self.general_public_holidays()
 def get_holiday_list(self):
     self.holiday_list.sort()
     return self.holiday_list
 def general_public_holidays(self):
     # Fix holidays
     self.holiday_list.append([datetime.date(self.year, 1, 1), u'Neujahr'])
     self.holiday_list.append([datetime.date(self.year, 1, 6), u'Heilige Drei Könige'])
     self.holiday_list.append([datetime.date(self.year, 5, 1), u'1. Mai'])
     self.holiday_list.append([datetime.date(today.year, 8, 1), u'Nationalfeiertag'])
     self.holiday_list.append([datetime.date(self.year, 12, 25), u'Erster Weihnachtsfeiertag'])
     self.holiday_list.append([datetime.date(self.year, 12, 26), u'Zweiter Weihnachtsfeiertag'])
     # Flexible holidays
     self.holiday_list.append([self.get_holiday(2, _type='minus'), u'Karfreitag'])
     self.holiday_list.append([self.easter_date, u'Ostersonntag'])
     self.holiday_list.append([self.get_holiday(1), u'Ostermontag'])
     self.holiday_list.append([self.get_holiday(49), u'Pfingstsonntag'])
     self.holiday_list.append([self.get_holiday(50), u'Pfingstmontag'])
 def get_holiday(self, days, _type='plus'):
     delta = datetime.timedelta(days=days)
     if _type == 'minus':
         return self.easter_date - delta
         return self.easter_date + delta
# Calculate Easter date
class EasterDay:
     self.year = year
 def get_k(self):
     k = self.year / 100
     return k
 def get_m(self):
     k = self.get_k()
     m = 15 + (3 * k + 3) / 4 - (8 * k + 13) / 25
     return m
 def get_s(self):
     k = self.get_k()
     s = 2 - (3 * k + 3) / 4
     return s
 def get_a(self):
     a = self.year % 19
     return a
 def get_d(self):
     a = self.get_a()
     m = self.get_m()
     d = (19 * a + m) % 30
     return d
 def get_r(self):
     a = self.get_a()
     d = self.get_d()
     r = d / 29 + (d / 28 - d / 29) * (a / 11)
     return r
 def get_og(self):
     d = self.get_d()
     r = self.get_r()
     og = 21 + d - r
     return og
 def get_sz(self):
     s = self.get_s()
     sz = 7 - (self.year + self.year / 4 + s) % 7
     return sz
 def get_oe(self):
     og = self.get_og()
     sz = self.get_sz()
     oe = 7 - (og - sz) % 7
     return oe
 def get_os(self):
     og = self.get_og()
     oe = self.get_oe()
     os = og + oe
     return os
 def get_date(self):
     os = self.get_os()
     if os > 31:
         month = 4
         day = os - 31
         month = 3
         day = os
     easter_day = datetime.date(self.year, month, day)
     return easter_day
holidays(today.year)
If I execute this script in terminal, I get the output "Today is a holiday" (or not) correctly. How can I use this script in Indigo as a condition? It fails on "import datetime"... Expexted end of line , etc. but found identifier
Update: Updated my code due to the help of autolog. I use the script now not as the condition but as the action.
Update 2: Updated my code with the ability to check if tomorrow is a holiday and I store now the name of the holiday
Fri Apr 03, 2015 5:23 am
Re: Using Python as a condition
Despite looking I can't find the relevant Indigo documentation but I suspect that it only allows Applescript and not Python. It could be an area that hasn't been updated yet?
I think this is the case because where you can use Python, Indigo normally lets you choose between Applescript and Python.
You don't say how you are trying to run this but assuming it is an a daily schedule, you might be better off including it as an action: Server Action > Script and File Actions > Execute Script.
You will also need to change your print statement to something like:
indigo.server.log(u'Today is a holiday')
If you are trying to set a variable you could do that in your script :)
Example from Indigo variable documentation:
indigo.variable.updateValue(123, value="New Value")
Fri Apr 03, 2015 5:39 am
Nine offline
[solved] Using Python as a condition
Ahh... could be the solution. If I use the script in the 'Action' tab (yes, I use it in a daily shedule) and changed the print statement to indigo.server.log(u'Today is a holiday') it works :D
Thanks a lot!
Sun Apr 05, 2015 4:14 pm
Correct, Python scripts can't currently be used in Conditions, though as that post indicates you can accomplish the same thing by pushing the conditional logic down into a script action.
Mon Sep 30, 2019 4:28 pm
Re: [solved] Calculate if today or tomorrow is a holiday
Indigo 7.4 is now available and includes support for Python embedded conditional scripts (inside Triggers and Schedules).
