- Code: Select all
execute script "Users:kg23:Documents:Indigo User Data:Scripts:set_entry_delay.scpt"
How can I trigger this from a Python script?
import os
scriptFile = "/Users/kg23/Documents/Indigo\ User\ Data/Scripts/set_entry_delay.scpt"
os.system("osascript " + scriptFile)
Error because embedded scripts execute sequentially they must complete their execution within 10 seconds.
Error modify the script to exit quickly or convert it to an external file (not embedded).
Stopping embedded script executor host (pid 6576)
Error process (pid 6576) failed to quit after polite request -- forcing it to quit now
kg23 wrote:
- Code: Select all
import os
kg23 wrote:I found out that this solution only works from an external script. Trying to run from an embedded Python script causes a timeout error.
- Code: Select all
import os
Users browsing this forum: No registered users and 20 guests
