Python - Turning on device when only device code is known
Wed Oct 30, 2013 7:52 pm
Trovan offline
How do I turn on a device when I only know the device code?
I'm trying to use this code as a template, but I don't think I'm on the right track with updatestateonserver. Any help?
def setDeviceLight(zone, lightmsg):
   for device in indigo.devices:
      if device.address == zone:
         device.updateStateOnServer("mode", mode)
Wed Oct 30, 2013 8:03 pm
Re: Python - Turning on device when only device code is know
updateStateOnServer() is a semi-private method that plugins are only allowed to call on device types they own/define. Instead, I think you want this:
indigo.device.turnOn(device)
where device can be a device instance (like you have in your loop), a device ID, or a device name.
Thu Oct 31, 2013 4:31 am
Trovan offline
This is the error I get when it tries to set the device...
File "plugin.py", line 50, in runConcurrentThread
File "plugin.py", line 143, in dispatchMsg
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Elk Plugin.indigoPlugin/Contents/Server Plugin/elkextra.py", line 56, in setDeviceLight
<type 'exceptions.ValueError'>: ElementNotFoundError -- could not find device "C12"
Line 56 is the turnOn(zone)...
With the following code
         indigo.device.turnOn(zone)
         indigo.server.log("Turned on")
Thu Oct 31, 2013 6:58 am
It looks like "zone" is the X10 address of your device, not its ID (ID is a unique internal integer assigned to every Indigo device). Instead use:
Or if you wanted to pass the ID (same result) it would be:
indigo.device.turnOn(device.id)
Thu Oct 31, 2013 4:08 pm
Trovan offline
Ok. This is fixed. I'm now able to update a device based on a command sent from the Elk-M1.
I have another question....Is there a way to have a callback or something in a plugin that will alert me when a device is changed?
I want to be able to change the device status in Indigo, and have the plugin send a command out to the Elk-M1.
Mark
Thu Oct 31, 2013 8:48 pm
If you build a plugin then you can subscribeToChanges which will call a method in the plugin each time any device changes.
If you don't want to build a full plugin you can just trigger off of any change just to the devices you care about and in the action run a script that talks to the elk.
Fri Nov 01, 2013 6:55 pm
Trovan offline
I setup subscribetochanges and I get zone changes in the log file, but not when I manually change an X10 zone.
What command do I use in a trigger script if I want to communicate with a plugin?
Sat Nov 02, 2013 5:26 am
Trovan offline
Nevermind. I found the issue.
Users browsing this forum: No registered users and 18 guests
