capture / save data to a txt file
Tue Jan 12, 2021 9:21 pm
Re: capture / save data to a txt file
And there are no errors written to the Indigo Events log? I'm at a loss. I run the script on my system and it works.
I wonder if there's something going on with the OneDrive folder permissions. Perhaps try another folder like the current User's downloads folder.
Tue Jan 12, 2021 9:38 pm
SMUSEBY offline
moved the target to 'downloads' - same non-result (file date updated, but no data).
Tue Jan 12, 2021 10:09 pm
When you say the file has no data, are you literally looking at an empty file or are you getting this message?
Screen Shot 2021-01-12 at 10.06.29 PM.png (105.22 KiB) Viewed 3021 times
Try changing the file extension to '.txt' instead of '.rtf'.
Tue Jan 12, 2021 10:15 pm
SMUSEBY offline
The rtf file is open w text edit, and blank. I’ll
Tue Jan 12, 2021 10:25 pm
SMUSEBY offline
Just confirmed that I was executing the right file (I am), and that there are no errors.
Jan 12, 2021 at 20:17:50
Trigger run a script #3
Script #3 calls the python script of interest.
Maybe I should log data to the event log?
Where did the screen shot above come from? - and to answer the question, I can open the document - it's blank. - but the file size is 434 bytes.
Clue: I just ran the script 3 times, and not the file size is 530 bytes.
white font??? This is bizarre.
Tue Jan 12, 2021 10:48 pm
SMUSEBY offline
fwiw, I just opened the file (on the tahoe computer) with both textedit and word on my berkeley computer, and there is nothing on the document in either app.
Wed Jan 13, 2021 7:38 am
If you've tried changing the name of the output file to .txt (the suggestion is very well hidden below the screenshot above) and it still isn't working for you, then I'm afraid I'm out of ideas.
If I change nothing but the id number and path to the file, the script works for me. The screenshot above is what I get when I double-click the 'rtf' file and Mac OS (Catalina) tries to open the file with Text Edit. However, if I right click on the file and select "Open with BBEdit" the file opens and contains valid data. If I change the extension from '.rtf' to '.txt' and then double-click on the file, it opens up in Text Edit. I can also preview it by selecting the file and hitting the space bar in Finder (when it has the .txt extension). I think the OS is having trouble because of the '.rtf' extension and the fact that it isn't a Rich Text File (it's a plain text file.)
Wed Jan 13, 2021 2:04 pm
SMUSEBY offline
rtf was the issue.
Now I can put the script to work.
Thank you!
Bob
Wed Jan 13, 2021 2:09 pm
Wahoo! My only regret is that I didn't think of this sooner. I hardly ever use Text Edit.
Good luck.
Wed Jan 13, 2021 2:14 pm
SMUSEBY offline
If it's not difficult, could you please help me to modify the script to parse the data?
2021-01-13 12:03:01.181000, 5.5
Date and Hr:Min is all I need.
Wed Jan 13, 2021 6:00 pm
That's no problem. Change this bit:
u"{0}, {1}\n"
to this:
u"{0: %Y-%m-%d %H:%M}, {1}\n"
Leaving the remainder of the line unchanged.
If you literally meant just the date, it's this:
u"{0: %d %H:%M}, {1}\n"
Wed Jan 13, 2021 6:14 pm
SMUSEBY offline
I meant ymd and hour:min, but the day only is better. Perfect.
btw, I created a second script in about 30 seconds by replacing the device ID and output file name. Very elegant. l have come to love python, and wish I had 10% of your capability.
Wed Jan 13, 2021 6:24 pm
You're too kind. I'm but a flea on the backs of some of the real developers around here.
I understand what you mean about Python. Once I came to appreciate how much you can do with even a simple understanding, it made it feel like anything may be possible with Indigo and Python combined.
