Mac Catalina Python 3 code conflict with Indigo Python 2
Sat Apr 04, 2020 1:19 pm
wiliamboatright offline
Re: Python not working with AppleScript (work-a-round)
Thanks again.
Just for FYI, the AppleScript part of the code Ilast posted works on as a file with Python 3.7 on Catalina OS. As per my first post in this topic, I have Indigo Python produce the thermostat data file.txt and send an email email to my Mac Maiil app. This triggers a mail app rule to run this AppleScript file that populates the Numbers spreadsheet with the file.txt data and the formulae. Been using this method for several weeks with no problems.
As I was wrong starting this topic under this Topic name, is there a way to change this topic's title name so that this topic does not infer a serious problem with Indigo Python and AppleScript? I wouldn't want to mislead people when they are searching this forum for answers.
Sun Apr 05, 2020 6:56 am
Again, not sure if best method, but it works. I used the Mac Script Editor app to export the AppleScript file as an application (option- Run Only). Then moved moved new app to Applications folder. The following code was embedded in the Indigo Python script.
import subprocess, sys
applescript = '''
Tell application "App Name"
   activate
end tell
args = [item for x in [("-e",l.strip()) for l in applescript.split('\n') if l.strip() != ''] for item in x]
proc = subprocess.Popen(["osascript"] + args ,stdout=subprocess.PIPE )
Sun Apr 05, 2020 7:38 am
Try editing your very first post that started this thread, and changing the title there.
Sun Apr 05, 2020 7:55 am
Re: Mac Catalina Python 3 code conflict with Indigo Python 2
That did change the thread title. Subsequent earlier posts' subject remained the same. At least people can see the new thread title and updated subject on new reply posts
Thanks.
