FileIOError
Thu Aug 30, 2018 10:14 pm
arminw offline
FileIOError
I just upgraded from version 6.1 to version 7.1. Everything seems to work except I get the following error messages:
Error DoSaveNow() caught exception: FileIOError -- file not closed or nested temp file failure
Error failed to save preferences
The errors happen at random time intervals and don’t seem to be connected to any other program activity. They show up in red along with normal activity events in the event log. All modules otherwise respond normally just the way they used to.[size=100]
[/size]
Fri Aug 31, 2018 8:52 am
Re: FileIOError
You might have a permission issue
Reinstall indigo will fix all permission issues in the indigo path.
Some of the plugin also write somewhere else. Check you home directory for the proper rights.
