Log Errors post-crash
Fri Apr 27, 2018 1:45 pm
HFTobeason offline
Hard crash of unknown origin. Reboot. Now seeing:
   Error (client)                  timeout waiting for server response for request GetControllerGroupNameForDeviceGroupNum
   Error (client)                  error calculating action description
   Error (client)                  received unexpected packet response GetControllerGroupNameForDeviceGroupNum (waiting for )
   SVG Error                       Error in plugin execution runConcurrentThread:
  File "plugin.py", line 50, in runConcurrentThread
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/SVG.indigoPlugin/Contents/Server Plugin/data.py", line 95, in monitorData
StandardError: ServerCommunicationError -- timeout waiting for response
   SVG Error                       plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
   TED - The Energy Detective ErrorError in plugin execution runConcurrentThread:
  File "plugin.py", line 63, in runConcurrentThread
   TED - The Energy Detective Errorplugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Fri Apr 27, 2018 5:22 pm
Re: Log Errors post-crash
Shut down the Indigo Server, manually move all plugins from:
to:
/Library/Application Support/Perceptive Automation/Indigo 7/Plugins (Disabled)
then start the server back up. If everything works, then start reenabling plugins one at a time.
If things still don't work, then copy/paste the entire Event Log contents into a reply post (there may be more useful information before what you posted above).
You might also want to do a shutdown/restart (rather than a reboot) of your Mac.
Fri Apr 27, 2018 8:43 pm
HFTobeason offline
Well, that seems to have worked!
Curiously, I had individually reloaded (from within Indigo) each of the plugins previously, but no joy. Hmmm...
Anyway, all good now.
Thank you!!!
