7.0.2 is not starting on restart or after crash on mini
Posted:
Tue Dec 13, 2016 11:41 pm
by PETStech
OS X El Capitan 10.11.6
Indigo 7.0.2
Alexa-Hue Bridge plugin installed and working
[checked] Auto start Indigo Server on user login, auto relaunch if crash.
Notes:
Auto start Indigo Server on user login [, Auto relaunch if crash. is missing]
Also RE: [url]http://wiki.indigodomo.com/doku.php?id=indigo_startup&s[]=boot[/url]
You can set your Mac to automatically log in to a specific user account at boot time in the Accounts system preference pane under Login Options.
Shouldn’t it say, “You can set your Mac to automatically log in to a specific user account at boot time in the Users & Groups system preference pane under Login Items.“
Re: 7.0.2 is not starting on restart or after crash on mini
Posted:
Wed Dec 14, 2016 10:11 am
by matt (support)
Unfortunately, we had to remove the auto-relaunch if crash capability several years ago because of a macOS bug. However, it should be starting up on user login automatically. Are you sure it isn't? Note the Indigo Server has no UI, so if it starts up in the background the only way to know is to launch the Indigo Client to look at the Event Log window details (or use Terminal or Activity Monitor to see if the IndigoServer process is running).
We'll get the wiki updated – thanks for the report.
Posted:
Thu Dec 15, 2016 12:30 pm
by PETStech
I rebooted, then checked log as suggested. Indeed, Indigo 7 server had started. Since Indigo 7 didn't appear in the Force Quit list, I believed that the server hadn't started. Bad assumption, since Indigo 7 in that list refers to the client, not the server. Correct?
- Tom
Posted:
Thu Dec 15, 2016 3:44 pm
by matt (support)
Correct.
Posted:
Sat Oct 07, 2017 5:47 am
by agame
After a reboot of the Mac mini running Indigo, the Indigo server is relaunching correctly (I can control via e.g. the iPhone app).
But the client app is having difficulty finding the server (running on the same machine). I need to quit and manually relaunch the server for them to find each-other. It was a standard install on the same user account (or should have been!). Is there a workaround to this??
Posted:
Sat Oct 07, 2017 11:37 am
by matt (support)
Are you have the client start up as a macOS login item? That isn't recommended – it can try to start before the Indigo Server has started up and can accept connections. The client only really needs to start when you need to use/configure Indigo, so we recommend to use Indigo's built-in setting (in the Start Local Server dialog) to have the Indigo Server started then just launch the Indigo client when you need to use it. That will actually lower the CPU usage that Indigo Server needs if it doesn't have to communicate with a client.
Posted:
Sat Oct 07, 2017 7:13 pm
by agame
ah. yes thats the problem. thx.
