Multiple errors
Sun Nov 29, 2015 9:15 am
aderrington offline
Multiple errors
I'm seeing quite a few errors occuring in my log, and i've noticed that the timers (that i use a lot) are failing the past day or 2.
Any reason these would be showing?
Andrew
Timers and Pesters Error        Error in plugin execution runConcurrentThread:
  File "plugin.py", line 256, in runConcurrentThread
  File "plugin.py", line 91, in decrement
  File "plugin.py", line 66, in setSecondsLeft
<type 'exceptions.StandardError'>: ServerCommunicationError -- timeout waiting for response
  Timers and Pesters Error        plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
  Plex HTPC Error                 Error in plugin execution runConcurrentThread:
  File "plugin.py", line 46, in runConcurrentThread
  Plex HTPC Error                 plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
  Autolog Stella-Z Error          Error detected in Autolog Plugin runConcurrentThread Method 'B'
  Autolog Stella-Z Error            Error message: 'ServerCommunicationError -- timeout waiting for response'
  Hue Lights Error                Error in plugin execution runConcurrentThread:
  File "plugin.py", line 670, in runConcurrentThread
  File "plugin.py", line 2116, in getBulbStatus
Mon Nov 30, 2015 4:04 pm
Re: Multiple errors
This is likely the result of a plugin that's behaving badly. I'd start by disabling all the 3rd party plugins you have installed and seeing if the problem persists. If not, then reenable them one at a time (or in groups) until you narrow down the offender.
