May 30, 2015, 9:00:19 PM
Received INSTEON "HVAC Thermostat" on (button 1)
Trigger HVAC A/C Start Time
Received INSTEON "HVAC Thermostat" cool setpoint changed to 20.0
Received INSTEON "HVAC Thermostat" heat setpoint changed to 14.0
HVAC A/C Start time just records the time it started into a variable.
Didn't realize it until we were headed upstairs at 1030pm to go to bed...I said, "Honey, it's cold in here" and I thought I'll just check...and sure enough the house was down to 71 (cool setpoint is supposed to be 74 after 7:30pm). So I reset power to the HVAC, and then changed the setpoint back to what it should be.
Is there any way to figure out what is going on here? Is the thermostat going haywire? Or did Indigo command the setpoint? I have a Venstar T1800 thermostat.
This is kooky and a little scary...worried that someone could be inside my server. We've been having a LOT of screwy behavior the last few days (not just with the thermostat).
Best,
Phil
