- Posted on
Fri May 01, 2015 4:06 pm
aderrington
offline
It appears that the Thermostat and boiler do not send anything that Indigo could use to interpret the status of the boiler.....
In the log below, i set the thermostat to 23° so it turned the boiler on, I then turned it down to 19° so the boiler turned off..... Nothing relates to the boiler, only the thermostat.
Z-Wave Debug RCVD requestSetpointVal: 01 0C 00 04 08 13 06 43 03 01 22 00 E6 6F
Z-Wave Debug . . requestSetpointVal: node 019, endpoint None, type 1, raw value 2200...
Z-Wave Debug . . requestSetpointVal: 23.0 °C (float: 23.000000)
Z-Wave received "Living Room Thermostat" heat setpoint is 23.0 °C
Z-Wave Debug RCVD requestSetpointVal: 01 0C 00 04 00 13 06 43 03 01 22 00 E6 67
1 May 2015 15:49:17
Z-Wave Debug RCVD requestSetpointVal: 01 0C 00 04 08 13 06 43 03 01 22 00 BE 37
Z-Wave Debug . . requestSetpointVal: 19.0 °C (float: 19.000000)
Z-Wave received "Living Room Thermostat" heat setpoint is 19.0 °C
Z-Wave Debug RCVD requestSetpointVal: 01 0C 00 04 00 13 06 43 03 01 22 00 BE 3F
