- Code: Select all
Error script error: Can’t make characters 12 thru -1 of "" into type string. (-1700)
I looked back at the previous logs and it appears to have started on Friday 23th, I know, spooky. I've not run any recent updates on the Mac running Indigo, or any plugin updates, though I've since installed a couple before noticing the error - an INDIGOplotD update which is throwing up loads of errors (but that's for another tread), and WUnderground. Even with both of these turned off I still see the above error.
Restarted the server and still showing. I've searched the forums and see this error has previously appeared, but was meant to be fixed. Running the most current version of Indigo on Mavericks.
Any thoughts on this?
Simon
