- Posted on
Sun Nov 09, 2014 1:12 pm
colovin
offline
This system has been running fine for YEARS, suddenly a trigger won't disable. I have a motion detector with a trigger set to turn on lights in the morning thus it is call "Morning Trigger" Then I have a scheduled time (4:30 am) for the trigger to be enabled and a scheduled time (sunrise -12) for the trigger to be disabled. Then a scheduled time to turn all the morning lights off. Been working fine for years. Now the morning trigger won't go away. At noon if you go by the motion detector the morning lights come on. I've rebooted the computer which does not correct the situation. I've unchecked all the schedules and triggers, no joy. I've setup a variable in the trigger to "if current time is greater than 4:30 am / if current time is less than 6:47am still doesn't turn the thing off. Do I need to reset the modem? Not sure what to do here.
Indigo 7.1.1, OS 10.14.6, MacMini .3.2 GHz 6 Intel Core i7, 64 GB ram
