Here they are, from my Log (Unfortunately, they do not paste in RED, like the Log displays them.):
Aug 23, 2014, 12:29:04 PM
Starting Indigo Server version 6.0.14
Loading attachments
Aug 23, 2014, 12:29:24 PM
Loading plugin "Action Collection 1.4.11"
Starting plugin "Action Collection 1.4.11" (pid 700)
Loading interface "INSTEON Commands 2.0.4"
Starting interface "INSTEON Commands 2.0.4" (pid 701)
Loading interface "Z-Wave 1.0.256"
Starting interface "Z-Wave 1.0.256" (pid 702)
Loading plugin "DIRECTV DVR Control 1.0.0"
Starting plugin "DIRECTV DVR Control 1.0.0" (pid 703)
Loading plugin "iTunes 1.1.4"
Starting plugin "iTunes 1.1.4" (pid 704)
Loading plugin "Thermostat Enhancement Add-On 1.00"
Starting plugin "Thermostat Enhancement Add-On 1.00" (pid 705)
Loading plugin "Timers and Pesters 1.1.3"
Starting plugin "Timers and Pesters 1.1.3" (pid 706)
Loading plugin "User Scripts 1.0.0"
Loading interface "Virtual Devices 1.0.11"
Starting interface "Virtual Devices 1.0.11" (pid 707)
Loading plugin "WeatherSnoop 2.0.3"
Starting plugin "WeatherSnoop 2.0.3" (pid 708)
Found disabled plugin "Airfoil 1.1.6"
Found disabled plugin "EasyDAQ Relay Card 1.1.7"
Found disabled plugin "Growl 1.1.2"
Found disabled plugin "iCal Alarm Processor 1.1.0"
Found disabled plugin "NOAA Weather 1.1.0"
Found disabled plugin "SQL Logger 1.1.8"
Found disabled plugin "Vera Bridge 1.0.6"
Bonjour registered "Indigo - TRE INSTEON"
Error RunThread() caught exception: basic_string::substr
Error interface "Virtual Devices 1.0.11" (pid 707) failed to start -- restarting in 5 seconds
Error plugin "DIRECTV DVR Control 1.0.0" (pid 703) failed to start -- restarting in 5 seconds
Error plugin "iTunes 1.1.4" (pid 704) failed to start -- restarting in 5 seconds
Error interface "Z-Wave 1.0.256" (pid 702) failed to start -- restarting in 5 seconds[/color][/color]
Started interface "INSTEON Commands 2.0.4"
Started plugin "Timers and Pesters 1.1.3"
Started plugin "Action Collection 1.4.11"
Started plugin "Thermostat Enhancement Add-On 1.00"
Started plugin "WeatherSnoop 2.0.3"
WebServer client connected
WebServer started on port 8176 -- digest authentication enabled
Aug 23, 2014, 12:29:33 PM
Reloading interface "Virtual Devices 1.0.11"
Starting interface "Virtual Devices 1.0.11" (pid 743)
Reloading plugin "DIRECTV DVR Control 1.0.0"
Starting plugin "DIRECTV DVR Control 1.0.0" (pid 744)
Reloading plugin "iTunes 1.1.4"
Starting plugin "iTunes 1.1.4" (pid 745)
Reloading interface "Z-Wave 1.0.256"
Starting interface "Z-Wave 1.0.256" (pid 746)
Connected to PowerLinc 2413U interface on port usbserial-A4016NRY
PowerLinc address 1E.DB.8B, firmware version 9.11
Started interface "Virtual Devices 1.0.11"
Started plugin "DIRECTV DVR Control 1.0.0"
Started plugin "iTunes 1.1.4"
Started interface "Z-Wave 1.0.256"
Aug 23, 2014, 12:31:00 PM
Thermostat Enhancement Add-On Error Error in plugin execution startup:
File "plugin.py", line 57, in startup
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Thermostat.indigoPlugin/Contents/Server Plugin/versioncheck.py", line 26, in VersionCheck
File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/urllib2.py", line 126, in urlopen
File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/urllib2.py", line 397, in open
File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/urllib2.py", line 510, in http_response
File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/urllib2.py", line 435, in error
File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/urllib2.py", line 369, in _call_chain
File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/urllib2.py", line 518, in http_error_default
<class 'urllib2.HTTPError'>: HTTP Error 500: Internal Server Error
Aug 23, 2014, 12:33:30 PM
Received INSTEON "Band & Laundry Rooms' Thermostat #1 (75 / 64)" on (button 1)
Aug 23, 2014, 12:34:58 PM
Received INSTEON "Office Bill Thermostat #7 (73 / 64)" on (button 1)
Received INSTEON "Office Bill Thermostat #7 (73 / 64)" temperature changed to 73.5
Aug 23, 2014, 12:39:24 PM
Aug 23, 2014, 12:42:57 PM
Received INSTEON "Office Bill Thermostat #7 (73 / 64)" off (button 1)
Received INSTEON "Office Bill Thermostat #7 (73 / 64)" temperature changed to 72.5
Aug 23, 2014, 12:45:13 PM
Received INSTEON "Band & Laundry Rooms' Thermostat #1 (75 / 64)" off (button 1)
Aug 23, 2014, 12:46:24 PM
Received INSTEON "Band & Laundry Rooms' Thermostat #1 (75 / 64)" temperature changed to 74.5
Aug 23, 2014, 12:49:24 PM
Aug 23, 2014, 12:54:19 PM
Aug 23, 2014, 12:59:24 PM
Aug 23, 2014, 1:01:04 PM
Aug 23, 2014, 1:01:56 PM
Aug 23, 2014, 1:06:13 PM
Aug 23, 2014, 1:07:12 PM
Received INSTEON "Garage 3-Car Can Lights ON / OFF Garage Entry Door Switch" on
Aug 23, 2014, 1:08:15 PM
Received INSTEON "Garage 3-Car Can Lights ON / OFF Garage Entry Door Switch" off
Aug 23, 2014, 1:09:24 PM
Aug 23, 2014, 1:09:55 PM
Indigo Cocoa client connected
