Sorry to be late to this thread.
I am suffering the same cpu problems that has been reported here.
I am running Indigo on a Mac Mini 2011 (Core 2 Duo 2.66Ghz with 8GB RAM)
On this MacMini, Indigo is the only soft running 24h.
Other user's software that can be run (not full time) is iTunes and XBMC
Without regularity, the fan begin to run high speed (that's why I could be aware about the problem).
At this moment, I can see (using Activity monitor) that cpu usage is at 100% (both cores) And that the process is eating cpu is "IndigoServer"
I am not sure how many times by day it can happen. I only spend few hours near this Mac Mini.
So, I can not reproduce the problem.
If during this cpu pikes, I disable all the plugins ... IndigoServer continue consuming 100% cpu
But, I can not disable all the plugin during all the day (I could not enter inside my home
I do not believe that problem is due to release 6.0.13, This happened with 6.0.12
I updated the Mac Mini to Mavericks during January/2014
Before that, I was running Snow Leopard without any problem. (General stability was better with SL)
I don´t remember the latest Indigo release I used with SnowLeopard.
So, the problem came with Mavericks, or the Indigo Release around Jan/2014I am sorry not to give you more relevant information.
Regards,
Ramon
