when running indigo client and connecting to my home server across my home LAN, the connection drops a lot and i keep losing my state and having to reconnect.
for routine use, this is no big deal. my machine switches across different networks (home/work/public wifi/...) a few times a day and so it is not unexpected that when i leave the app unattended for a while, then come back to it, that i often have to wait for it to reconnect.
today for some reason, this problem is worse than normal and my connections are only staying up for about 30-60 seconds on average.
i assume the protocol used by indigo is based on TCP, so should be able to overcome low levels of packet loss, correct? is there a timeout or something that would cause the connection to timeout? i can't imagine this being the problem either, because i know in the past i've connected to my mac from outside the country without a problem. latency from my laptop running indigo client to my server is only 4-6ms (due to use of wifi). packet loss (measured by simple ping) is around .5% or less.
any ideas what might cause the connection to drop so often on a low-latency, medium-high reliability connection?
