Hi There,
I'm trying to use a remote dektop client (4.0.0b5) over goprism. When I run the client, the Server Connection Status dialog comes up. When I type in https://myreflector.goprism.com and then hit the Connect button, I get a message that says "Failed to connect to Indigo server. The Indigo server is either unreachable over the network or is not running."
If I bypass prism and enter in the ip address in the client, I am able to connect without a problem. (My router has a fixed address which forwards the port (1176) to the specific mac running Indigo Server)
Also, when I attempt to connect via Indigo Touch, or from a browser, then I am able to connect through prism without issue. The problem appears to be limited to a remote Indigo desktop client accessing via prism.
Any ideas?
Bob E.
