Reflector newbie looking for advice. Indigo 7.5 going 2021.
Posted: Fri Oct 08, 2021 8:28 pm
Before going with Reflector I was going straight to my IP, with firewall, port forwarding etc.
I'm hoping to use Alexa once upgraded to 2021.x.x. I've been reading/researching before jumping off the cliff and found that the Reflector is needed to make Alexa work. Unless I've read it all wrong of course.
Reflector traffic may be a concern, but since I don't do much, if any, image transfers it may be a non issue. The only thing I'm using/concerned about, however slightly, is a control page for my DSC Alarm Panel. First outing was today and I noticed Indigo Touch went on pause after a brief time. I assume that's normal so as to keep traffic within reason.
Finally my question
If I leave my direct access up as well as WiFi and Reflector do I have to do some manual switching in Indigo Touch when I leave my LAN/WiFi?
To put it another way, what is the best configuration to use my Public IP when away from home yet WiFi and Alexa when at home.
Hopefully I'm just overthinking
Finally my question
