- Posted on
Sat Feb 10, 2007 1:51 pm
ajturner
offline
Hi Jim - glad everything worked well for you on setup.
Regarding HTTP access, currently both HTTP and HTTPS are provided - as some devices or browsers that users may use don't handle HTTPS. So you are free to connect through either protocol.
In the future, for general security, we may disable HTTP access and only allow HTTPS.
As for logging into your actual Prism Reflector. When you activated your Reflector in Indigo, it probably warned you that you should turn on security access to your server. This is configured in Indigo for your computer. Prism doesn't require you to protect your system.
However, it's assumed that you probably want to turn access control on, unless you like random people (or friends/family) playing tricks on you.
To turn it on, go to "Indigo 2" in the menu bar, and choose "Start Local Server". In the dialog box that comes up, turn on "Require authentication" and you should now be set.
Andrew
Control Indigo from anywhere in the world:
http://highearthorbit.com/software/indigowidget
