Reflector errors
Wed Mar 24, 2021 2:29 pm
Re: Reflector errors
From my previous post:
Copy/paste your entire Event Log window (after an Indigo Server restart) into a reply so we can get more of a scope on the problem.
If you aren't comfortable posting it to the forum then email it to us.
Wed Mar 24, 2021 6:06 pm
I just sent you an email off-forum with some additional troubleshooting steps.
Thu Mar 25, 2021 2:55 am
davinci offline
Thanks matt.
After stopping the server and deleting this file the error is gone.
/Library/Application Support/Perceptive Automation/Indigo 7.5/Preferences/Indigo Registration.indiPref
Tue Nov 14, 2023 9:18 am
SearchCz offline
Me too?
I'm having troubles that I think all relate to this error message that's popping up in my log:
Error Unable to authenticate with IndigoDomo.com (server might be down temporarily for maintenance).
I am able to successfully access my "Indigo Touch for Web" reflector from the Mac that hosts my Indigo 2022.2 server. But when I cannot mange or deactivate my license, and when I attempt an update to 2023.1, running that new server throws an error popup about my trial license being expired. (I am on a current up-to-date license).
Any idea how I can isolate and fix this problem so I can update my server to 2023?
Tue Nov 14, 2023 9:47 am
That error is normally caused by a network connectivity problem (which could be anywhere: your LAN, ISP, or the routers between your ISP and our hosted server).
Can you access this URL from your Mac running the Indigo Server?
https://indigodomo.com
and does Indigo ever create the reflector connection?
Thu Nov 16, 2023 9:11 am
SearchCz offline
Adter I deleted my Indigo Registration.indiPref I was able to log in and all my authentication and reflector issues were resolved.
Thu Nov 16, 2023 10:15 am
gadgetnut offline
Thank you @SearchCZ, thank you @davinci, thank you @Matt
After stopping the server and deleting this file:
/Library/Application Support/Perceptive Automation/Indigo 2023.1/Preferences/Indigo Registration
I rebooted, I was able to log in and all my authentication, authorization, and Indigo Smarthome Skill integration with Alexa problems were resolved.
Alexa voice control under macOS Sonoma and Starlink is working normally again.
Thu Nov 16, 2023 10:20 am
Glad that worked for you. I can't see how that corrected a network error, but the end result is that it works!
