how do i log a variable value?
Sun Dec 18, 2005 12:42 pm
dtich offline
what is the as syntax to write the value of a var to the log?
i'm trying stuff, but getting var not defined errors.
tia.
Sun Dec 18, 2005 3:14 pm
ajturner offline
(No subject)
This should work
   on LogAllVars()
      repeat with curVariable in variables
         set logMsg to name of curVariable & " = " & value of curVariable
         log logMsg using type "Variable"
      end repeat
   end LogAllVars
You then can call LogAllVars() from an embedded Applescript.
Control Indigo from anywhere in the world:
http://highearthorbit.com/software/indigowidget
