2413U or 2414U
Wed Dec 07, 2011 7:47 am
johnpolasek offline
2413U or 2414U
Questoin: I have an EZIO2X4 on order to go with a 0-5 v pressure sensor that I intend to use to monitor water depth in a cistern. The Indigo system that will be tied to this device is currently using a 2414U. However, when I looked at the detailed command set for the EZIIO, it appears that while the alarm trip on the 0-5 analog input is a standard length command, the actual digitized analog value is an extended command. So does this unit require a 2413U in order to get the actual pressure value like the Imeter solo does for the actual power usage? Or does Indigo (5.02 pro) even support that function?
Wed Dec 07, 2011 9:00 am
Re: 2413U or 2414U
Indigo can read the analog values from the EZIO modules using normal (not extended) commands, so the 2414u should work fine.
