SmartLinc 2412N
Fri Jan 23, 2009 2:14 am
kauihou offline
SmartLinc 2412N
Is there anyway to get Indigo to work with a SmartLinc 2412N?
Fri Jan 23, 2009 9:56 am
Re: SmartLinc 2412N
Wed Jan 28, 2009 10:11 pm
jlockyer offline
Re: SmartLinc 2412N
It is our (SmartHome's) goal to provide a pass-through mode for the SmartLinc Controller so that if Ethernet data is sent to Port x-x-x-x of the SmartLinc, those signals would just be passed through the SmartLinc Ethernet daughter board to the PowerLinc Modem main board. This ability and Matt's support to have Indigo speak "PLM" is about a year away. When this happens, I expect Matt and his software to be the first to support it :D
John
Thu Jan 29, 2009 7:48 am
Re: SmartLinc 2412N
Hi John,
Sounds good to me. :-)
And for everyone else, note that Indigo will likely support the USB PLM, which is not the Ethernet based SmartLinc John is talking about, much sooner. The USB PowerLinc PLM is their power line modem that works like the PowerLinc 2414U but does not have an internal timer or ability to run standalone. It does, however, have the ability to send extended data commands which will improve the performance of link management and add the ability to send some extended data-only commands.
This probably will not be in version 4.0, but supporting the PowerLinc PLM is a high priority.
Thu Sep 10, 2009 9:49 am
skidblad offline
Re: SmartLinc 2412N
Hi there,
Any update regarding support for 2412N?
-skd
Thu Sep 10, 2009 10:17 am
Re: SmartLinc 2412N
Nope -- no new news or developments.
Thu Sep 10, 2009 10:33 am
jlockyer offline
Re: SmartLinc 2412N
We are still working towards this goal. We are up to the point of internal testing with HouseLinc software. I think the feature will be introduced the beginning next year.
John
Thu Dec 10, 2009 11:09 am
AliasNode offline
(No subject)
Any update on this? Are you still on schedule for early 2010?
Will the new API be published somewhere?
Also wondering if it will just be a software update to the existing hardware, or if it will be a new model of the SmartLinc.
Sun Dec 12, 2010 11:16 am
joehuber offline
Re: SmartLinc 2412N
Any update on the 2412N direct PLM support?
Sun Dec 12, 2010 4:26 pm
Re: SmartLinc 2412N
Mon Jun 20, 2011 5:36 pm
aaaha offline
Re: SmartLinc 2412N
I see in this posting that the raw PLM protocol is accessible on the 2412N's TCP Port 9761. This would make the port equivalent to the 2412S, just a TCP/IP connection instead of serial. Is there any reason this couldn't be implemented?
Mon Jun 20, 2011 5:43 pm
Re: SmartLinc 2412N
Adding support for it is on our list, but at this time it isn't a high priority.
Unfortunately, I think what most users expect out of 2412N support in Indigo isn't just a network based PLM, but they want Indigo to support uploading logic/timers to it for standalone operation (and/or remote Indigo Touch access without their Mac running/awake) which is quite a different and more complex feature.
Mon Jun 20, 2011 6:41 pm
aaaha offline
Re: SmartLinc 2412N
I am very interested in a networked PLM solution as it would allow me to place the controller near my breaker box while keeping my Mac mini in my closet upstairs.
Wed Dec 14, 2011 4:31 pm
GhostZero offline
Re: SmartLinc 2412N
Any update? I figured I'd get the smartlinc to replace my dead powerlinc because my needs are simple, but come to find out that they aren't as simple as the smartlinc. :D
Wed Dec 14, 2011 4:42 pm
Re: SmartLinc 2412N
No updates. It is still on our list but there are several higher priority items above it. I'm not sure when, or if, we'll get to 2412N support.
