Osram Lightify
Sat Aug 12, 2017 5:15 pm
dz1rfj offline
Re: Osram Lightify
With certain versions of hue firmware, the osram lights will pair directly to hue hub. Once paired to hue hub, indigo plugin will work fine, controlling hue devices.
Sat Sep 02, 2017 12:13 am
Coolcaper offline
Re: Osram Lightify
geraldS wrote:
Hi Nathan,
i have added 2 additional Osram Lightify products to the supported devices file:
LIGHTIFY Flex RGBW
LIGHTIFY CLASSIC A60 RGBW
maybe you can add it into the official plugin in a future release.
Gerald
changes to supportedDevices.py:
# Classic A60 RGBW = Osram Lightify CLA60 RGBW
# Flex RGBW = Osram Flex RGBW
# (compatible Hue bulb devices) Color and Color Temperature
kHueBulbDeviceIDs = ['LCT001', 'LCT002', 'LCT003', 'LCT007', 'LCT010', 'LCT011', 'LCT014', 'LLC010', 'LLM001', 'HBL001', 'HBL002', 'HBL003', 'HEL001', 'HEL002,' 'HIL001', 'HIL002', 'FLS-PP3', 'Classic A60 RGBW']
# (compatible Ambiance devices) Color Temperature only
kAmbianceDeviceIDs = ['LLM010', 'LLM011', 'LLM012', 'LTW001', 'LTC003', 'LTW004', 'LTW013', 'LTW014', 'HML001', 'HML002', 'HML003', 'HML004', 'HML005', 'HML006']
# (compatible LivingColors devices) Color only
kLivingColorsDeviceIDs = ['LLC001', 'LLC006', 'LLC007', 'LLC011', 'LLC012', 'LLC013', 'LLC014', 'LLC020']
# (compatible LightStrips devices) Color only on LST001. Color and Color Temperature on LST002.
kLightStripsDeviceIDs = ['LST001', 'LST002', 'Flex RGBW']
Hi Nathan,
I recently bought the Classic A60 RGBW lights and the PAR16 50 TW lights. Both lights have been successfully added to the hue hub and I can see it in the iOS app. However, they do not show up in the plugin. I tried editing the file above to no avail. I also don't see the Classic A60 RGBW in the supported devices. I am on plugin version 1.6.5. Btw, the PAR16 50 TW will be a Color Temperature only device.
Sat Sep 02, 2017 12:26 am
nsheldon offline
Re: Osram Lightify
Hi.
Thanks for the report. In the iOS app, if you go to Settings then Info, what do you see listed as the "Model" for the 2 new lights you've paired with the Hue hub? I might need to add them to the Hue Lights plugin supported devices.
Sat Sep 02, 2017 1:41 am
Coolcaper offline
Osram Lightify
Hi Nathan,
Funnily there's no info about the model in the app.
Sat Sep 02, 2017 2:49 am
nsheldon offline
Re: Osram Lightify
Hi again.
Okay, then I'll need to get a debug log dump from you. Enable debug logging with the Plugins -> Hue Lights -> Toggle Debug Logging menu option then reload the plugin with Plugins -> Hue Lights -> Reload. Paste in the entire log content from when you reload the plugin to where is shows "Loaded xxx lights" (where xxx is the number of lights it loaded). I'll look through that debug log and find what model ID those lights are showing up as so they can be added to the compatible device list in the plugin.
Sat Sep 02, 2017 3:07 am
Coolcaper offline
Re: Osram Lightify
Hi Nathan,
Was just looking through the app and in the Settings > About area I can see the models just as described above one is listed as Classic A60 RGBW and the other is PAR16 50 TW. I will post the log dump as well.
Sat Sep 02, 2017 3:28 am
Coolcaper offline
Re: Osram Lightify
deleted as purpose served and so as not to expose any hackable details :shock: :wink:
Sat Sep 02, 2017 7:26 am
Re: Osram Lightify
I was told pretty definitively that the Osram Lightify Gardenlights are not the right version of Zigbee to work with a Hue Hub. Has this changed somehow? Perhaps I have an older model.
Couldn't make them even power up last time I tried anyway.
Refugee from SmartThings and so happy to be on Indigo now.
Sierra on an i5 running Harmony Hub, Hue, Security Camera, DomoPad, EPS Device Extensions EPS Smart Dimmer, MatplotLib, Plex, Scale Adapters, uniFiAP, Wunderground.
Sat Sep 02, 2017 2:11 pm
nsheldon offline
Re: Osram Lightify
Version 1.6.6 Posted
  • Added support for the Osram Classic A60 RGBW color bulb.
  • Added support for the Osram Flex RGBW color light strip.
  • Added support for the Osram PAR16 50 TW color temperature bulb.
  • Updated the supported features of the Osram Classic A60 TW color temperature bulb to correctly reflect its color temperature support.
Sat Sep 02, 2017 9:36 pm
Coolcaper offline
Re: Osram Lightify
Thanks Nathan. And thanks again for the wonderful plugin!
Sat Sep 02, 2017 11:06 pm
nsheldon offline
Re: Osram Lightify
Glad to help and that it's working for you.
