States not Showing in Indigo
Thu Sep 25, 2014 2:09 pm
Sleepy81 offline
Re: States not Showing in Indigo
Did that and restarted plugin.
Reloading plugin "Sonos 0.6.20"
Stopping plugin "Sonos 0.6.20" (pid 2935)
Sonos Debug Method: stopConcurrentThread
Sonos Debug Stopping device: Sonos PLAY3
Sonos Debug Method: shutdown
Z-Wave received "Bevegelsessensor Stue" status update is off
Stopped plugin "Sonos 0.6.20"
Starting plugin "Sonos 0.6.20" (pid 2952)
Sonos OSTYPE: 13
Sonos Subscribing on port: 9999
Started plugin "Sonos 0.6.20"
Sonos Your plugin version, v0.6.20, is current.
Sonos Debug Getting Plugin Configuration Settings
Sonos Debug Reference ZP IP: 192.168.0.127
Sonos Debug Publish/Subscribe Port: 9999
Sonos Debug Pandora: False
Sonos Debug Pandora User ID:
Sonos Debug Pandora Email Address:
Sonos Debug SiriusXM: False
Sonos Debug SMB Path:
Sonos Saved Plugin Configuration
Sonos Debug Loading Playlists...
Sonos Debug ZP: <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:BrowseResponse xmlns:u="urn:schemas-upnp-org:service:ContentDirectory:1"><Result><DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"></DIDL-Lite></Result><NumberReturned>0</NumberReturned><TotalMatches>0</TotalMatches><UpdateID>0</UpdateID></u:BrowseResponse></s:Body></s:Envelope>
Sonos Debug Loading RadioTime Favorite Stations...
Sonos Debug ZP: <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:BrowseResponse xmlns:u="urn:schemas-upnp-org:service:ContentDirectory:1"><Result><DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"></DIDL-Lite></Result><NumberReturned>0</NumberReturned><TotalMatches>0</TotalMatches><UpdateID>8</UpdateID></u:BrowseResponse></s:Body></s:Envelope>
Sonos Debug ZonePlayer: Sonos PLAY3, Enabled: True
Sonos Debug Resetting States for zone: 192.168.0.127
Sonos Debug Updating Device: Sonos PLAY3, State: ZP_ALBUM, Value:
Sonos Debug Updating Device: Sonos PLAY3, State: ZP_ART, Value:
Sonos Debug Updating Device: Sonos PLAY3, State: ZP_ARTIST, Value:
Sonos Debug Updating Device: Sonos PLAY3, State: ZP_CREATOR, Value:
Sonos Debug Updating Device: Sonos PLAY3, State: ZP_CurrentURI, Value:
Sonos Debug Updating Device: Sonos PLAY3, State: ZP_DURATION, Value:
Sonos Debug Updating Device: Sonos PLAY3, State: ZP_INFO, Value:
Sonos Debug Updating Device: Sonos PLAY3, State: ZP_MUTE, Value:
Sonos Debug Updating Device: Sonos PLAY3, State: ZP_STATE, Value:
Sonos Debug Updating Device: Sonos PLAY3, State: ZP_STATION, Value:
Sonos Debug Updating Device: Sonos PLAY3, State: ZP_TRACK, Value:
Sonos Debug Updating Device: Sonos PLAY3, State: ZP_VOLUME, Value:
Sonos Debug Updating Device: Sonos PLAY3, State: ZP_VOLUME_FIXED, Value:
Sonos Debug Updating Device: Sonos PLAY3, State: ZP_ZoneName, Value:
Sonos Debug Updating Device: Sonos PLAY3, State: ZP_LocalUID, Value:
Sonos Debug Updating Device: Sonos PLAY3, State: ZP_AIName, Value:
Sonos Debug Updating Device: Sonos PLAY3, State: ZP_AIPath, Value:
Sonos Debug Updating Device: Sonos PLAY3, State: ZP_NALBUM, Value:
Sonos Debug Updating Device: Sonos PLAY3, State: ZP_NART, Value:
Sonos Debug Updating Device: Sonos PLAY3, State: ZP_NARTIST, Value:
Sonos Debug Updating Device: Sonos PLAY3, State: ZP_NTRACK, Value:
Sonos Debug Updating Device: Sonos PLAY3, State: Q_Crossfade, Value: off
Sonos Debug Updating Device: Sonos PLAY3, State: Q_Repeat, Value: off
Sonos Debug Updating Device: Sonos PLAY3, State: Q_Shuffle, Value: off
Sonos Debug Updating Device: Sonos PLAY3, State: GROUP_Coordinator, Value:
Sonos Debug Updating Device: Sonos PLAY3, State: GROUP_Name, Value:
Sonos Debug Updating Device: Sonos PLAY3, State: ZP_CurrentTrack, Value:
Sonos Debug Updating Device: Sonos PLAY3, State: ZoneGroupID, Value:
Sonos Debug Updating Device: Sonos PLAY3, State: ZoneGroupName, Value:
Sonos Debug Updating Device: Sonos PLAY3, State: ZonePlayerUUIDsInGroup, Value:
Sonos Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 58, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 146, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 225, in initZones
File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/encodings/utf_8.py", line 16, in decode
<type 'exceptions.UnicodeEncodeError'>: 'ascii' codec can't encode character u'\xf8' in position 2: ordinal not in range(128)
Sonos Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Sonos Debug Method: runConcurrentThread
Sonos Debug Running Concurrent Thread
Sonos Debug Vaidating Plugin Configuration
Sonos Debug Validation Succesful
Same error as far as I can tell...
Thu Sep 25, 2014 3:33 pm
nlagaros offline
When you configured the ZonePlayer itself in the Sonos app, what did you name it? I traced back through the source code and it is failing on the line that writes the ZonePlayer name to one of the states in Indigo.
Thu Sep 25, 2014 4:26 pm
nlagaros offline
It would help if you could also try navigating to the following url and posting the results here: http://192.168.0.127:1400/status/zp
Fri Sep 26, 2014 8:41 am
Sleepy81 offline
Ah... That might be the reason.
I named my Sonos "kjøkken" which means "kitchen" in Norwegian.
The ø character is probably making a problem here. I guess that's why the error referes to an ASCI error.
Norwegians have the following special characters in their alphabet: æ, ø and å.
Maybe the plugin could be updated to support those characters some time in the future.
I will rename my sonos and test when I get back home. Will report the results here.
Fri Sep 26, 2014 9:17 am
Sleepy81 offline
That was it!
Changed the name to "Kjokken" and that made the plugin work perfectly!
Thanks for the help! Great plugin you´ve made here!
Fri Sep 26, 2014 1:37 pm
nlagaros offline
Glad it's working. I've already updated the plugin so you should be able to change the name back once I post the new version.
Sleepy81 wrote:
That was it!
Wed Apr 29, 2015 9:05 am
ToonDoom offline
Hi I am also having the following issue:
WARN coherence Apr 29 16:00:25 Coherence UPnP framework version 0.6.6.2 starting... (coherence/base.py:283)
WARN coherence Apr 29 16:00:55 hostname can't be resolved, maybe a system misconfiguration? (coherence/base.py:291)
My computer name is steveserver, "computers on my local network can use steveserver.local". I've tried doing DNS forward reverse checks (I used dig and dig ns but don't know what I'm looking for here. Any further suggestions?
Thanks in advance.
Thu Apr 30, 2015 1:10 am
ToonDoom offline
I have hacked my base.py for Coherence to default to the correct ip address when the look up fails. Not ideal but working for now.
Sat May 02, 2015 6:18 pm
DU Lou offline
Hi Nathan,
I am also running v0.8.13 and my device states have stopped updating.
Screen Shot 2015-05-02 at 8.13.30 PM.png (11.58 KiB) Viewed 4112 times
Screen Shot 2015-05-02 at 8.13.42 PM.png (11.88 KiB) Viewed 4112 times
:::Break::::
My album art also stopped updating. Would you prefer I post this symptom in another thread?
Thanks for the support as always!
~Lou
Fri May 08, 2015 4:33 pm
DU Lou offline
DU Lou wrote:
Hi Nathan,
:::Break::::
~Lou
Please disregard the above. Both issues have self corrected with some unicorns and FM :) maybe a reboot or 5 helped too....
Sat May 23, 2015 10:52 am
nlagaros offline
Would you point me to the changes you made? I'd like to add some logic to do this automatically. Thanks.
Sat May 30, 2015 11:07 am
nanobots offline
Hi @nlagaros,
I was having the same problem:
Sonos Debug                     SonosEvents: WARN  coherence                   May 30 09:04:02  Coherence UPnP framework version 0.6.6.2 starting... (coherence/base.py:283)
Sonos Debug                     SonosEvents: WARN  coherence                   May 30 09:04:02  hostname can't be resolved, maybe a system misconfiguration? (coherence/base.py:291)
Sonos Debug                     SonosEvents: WARN  coherence                   May 30 09:04:02  detection of own ip failed, using 127.0.0.1 as own address, functionality will be limited (coherence/base.py:308)
I solved this by changing your Sonos.py to specify the interface to bind to when instanciating the control_point variable (Sonos.py line 139) as follows. (notice the "interface" option that was added):
           control_point = ControlPoint(Coherence({'logmode':'warn','logfile':'coherence.log', 'controlpoint':'no', 'interface':'en0'}), auto_client=['ZonePlayer', 'MediaRenderer'])
Not sure how you want to address the issue, but this does seem to solve it for me at least.
Sun May 31, 2015 12:22 pm
AndyVirus offline
Hello,
I have never seen states so I did not know they were even availible for use till now. I was hoping they were able to be used, specifically to use the mute button as a trigger to reset a variable but no states have ever shown up for me. I can control the sonos speakers just fine just no state is ever shown in indigo.
My Coherance.log shows this: http://pastebin.com/z59dvhJn
My Debug output shows this: http://pastebin.com/uKVakELA
My status/zp shows:
ZoneName Kitchen
ZoneIcon x-rincon-roomicon:kitchen
Configuration 1
LocalUID RINCON_B8E937E9CA6401400
SerialNumber B8-E9-37-E9-CA-64:C
SoftwareVersion 28.1-86173
MinCompatibleVersion 27.0-00000
LegacyCompatibleVersion 24.0-0000
HardwareVersion 1.8.3.7-2
DspVersion 0.25.3
HwFeatures 0x0
IPAddress 192.168.123.87
MACAddress B8:E9:37:E9:CA:64
Copyright © 2004-2014 Sonos, Inc. All Rights Reserved.
ExtraInfo OTP:
HTAudioInCode 0
IdxTrk
Any Ideas?
Sat Oct 15, 2016 11:37 am
george99 offline
Has this ever been solved?
I just tried to start using sonos in indigo, and I have 2 connects, and 2 connect:amps. The connects keep losing the state. The state does not show in indigo. Only way I have found to get it back is via a factory reset for the sonos. But then it goes a way again. Basically unusable. I am not using any special characters in the names.
Tue Oct 18, 2016 6:25 pm
mclass offline
I've scheduled a regular reload (rather than "factory reset") of the Sonos plugin to overcome this issue - brute force rather than finesse!
mclass
