OWServer v0.6.7 is now available.
v0.6.7:
- Changes plugin file naming conventions to correct problems with some installations. This update is only necessary for installations that do not display the plugin Config menu option.
- Adds support for EDS0064 (Temperature Sensor with Counter)
Adds support for EDS0065 (Temperature and Humidity Sensor)
Adds support for EDS0066 (Temperature and Barometric Pressure Sensor)
Adds support for EDS0070 (Vibration Sensor)
Adds support for EDS0071 (RTD Interface, 4 Wire)
Adds support for EDS0080 (Octal 4-20 Milliamp Input)
Adds support for EDS0082 (Octal Current Input)
Adds support for EDS0083 (Quad 4-20 Milliamp Input)
Adds support for EDS0085 (Quad 0-10 Volt Input)
Adds support for EDS0090 (Octal Discrete IO)
- Adds config setting for sensors with/without optional relay.
- Adds temperature adjustment field to allow for fine-tuning
sensor temperature values (value in °C.) For example, entering a
value of -1 will adjust the temperature reading by -1°C or by -1.8°F.
- Adds Indigo Action item to update all sensor devices.
- Adds Indigo Action item to send command to a 1-Wire device.
- Adds Indigo Menu item to send command to a 1-Wire device.
- Updates DS2408 to allow selection of switches 0-7 as the primary
sensor display value.
- Implements Indigo custom device state icons for all switches,
relays, and LED states to reflect on or off.
- Fixes bug where some devices did not properly track LED and Relay
states.
- Moves server communication test from plugin configuration menu to
the Indigo plugin menu (reduces clicks to run the test) and allows
user to send XML output to the Indigo log (useful when trouble-
shooting problems.)
- Reorders sensor list by sensor number rather than name for easier
identification.
- Code enhancements:
- Fixes some device state data types.
- Simplifies configuration validation code.
- Simplifies data parsing routines.
- Standardizes device display preferences. May require users to
reselect default display value for some devices.
pluginId = "com.fogbert.indigoplugin.OWServer"
plugin = indigo.server.getPlugin(pluginId)
props = {"server": "10.0.1.123", "romId": "2A700003C74F4528", "variable": "clearAlarms", "value": "0"}
if plugin.isEnabled():
plugin.executeAction("sendToServerAction", props)
