Find My iDevices! (April 2013+)
Thu Dec 11, 2014 9:56 am
Jpaction offline
Re: Find My iDevices! (April 2013+)
Maybe Apple changed something again. I am getting the following.
Find My IDevices Error Unable to reach update server.
Sat Dec 13, 2014 1:33 am
Jpaction offline
Is no one else having this problem? It seems that Apple changed their login and even the device list doesn't show up in the drop down.
Sat Dec 13, 2014 2:09 am
VincentS offline
Yes I do have the same problem here, I tried almost everything but i gave up on it. Trouble is that a lot of triggers are not working anymore now cause they where depending on states of the location of my telephone. So I was wondering if there is another tracking solution. (smartphone radar is not working ok because it seems that when I leave my telephone untouched for more then one hour it status already changes to away and I have to physically connect it to the internet again by checking mail or so)
I think it indeed has to do with the login of Apple cause the problem a cured suddenly. When I deleted FMID and reinstalled it already said "unable to connect to update server" Also when I create a device it only says "none" even when I leave the popup, pres save, etc..
Sun Dec 14, 2014 12:49 am
Jpaction offline
I am going to try converting over to GeoHopper. It's unfortunate that Apple is making a really wonderful plugin useless.
Sun Dec 14, 2014 2:45 am
hensed offline
I have dozens of triggers (temp, alarm, door locks, lighting) that depend on this. Thanks a lot Apple! I love you, but geesh, you really stuck it to me on this one. :(
Sun Dec 14, 2014 3:55 am
Shutter offline
In fairness I would rather have the security that Apple now offers with iCloud than some unsupported, reverse engineered plugin.
Sun Dec 28, 2014 8:18 pm
sgtwicki offline
I'm having the same problem as Jpaction, but I was attempting to install the plugin for the first time. I thought I was doing it wrong, but after reading this thread, I realized I'm not crazy or incompetent. :D
Wed Jan 21, 2015 12:13 am
hensed offline
...still crying.... my houses no longer adjust to me being on my way, gone away. I had over 20 scripts and triggers that used this. Such a great plugin.
Wed Jan 21, 2015 12:52 am
GlennNZ offline
Had same issue....
But replaced with phone app Geofency (note spelling) on IOS and indigo Beecon plugin.
Working really well - no noticeable battery drain and added bonus of iBeecon support
Glenn
Wed Jan 21, 2015 6:18 am
Seeker offline
GlennNZ wrote:
Had same issue....
Glenn
Can you expand on this solution?
Wed Jan 21, 2015 3:19 pm
GlennNZ offline
Sure - not to much to expand on.
But run Geofency iOS app
https://itunes.apple.com/au/app/geofency-time-tracking-automatic/id615538630?mt=8
on iphone or equivalent - set up Geofences (seemingly based on GPS but also Wifi connection and other aspects)
As noted have not found a noticeable battery drain.
Beecon plugin - http://forums.indigodomo.com/viewtopic.php?p=79507&t=11935
as per that forum - creating devices for each location.
Geofency - change the webhook settings to point to indigo/Beecon plugin IP and Port.
Everytime you exit or enter a location a notification can be sent to indigo.
Glenn
