New version of the RFXTRX Plugin available
Thu Aug 15, 2013 2:06 pm
RJdeKok offline
Re: New version of the RFXTRX Plugin available
There is a new version available here (1.3.6): -- link removed – use link on first post for most recent version --
- Bug fix
Thu Aug 15, 2013 3:31 pm
steve: how to access through variables:
==> copy device status into variable (eg rainSensor into variables)
1. create all the variables you need (rainToday, rainRate, rainYesterday, ...)
2. create action group rainsensorToVariables
- Variable action / insert device state into variable / select device /edit action / select state and variable e.g. rainToday
- 2. action .. for 2. variable
3. create trigger eg rainsenorHasChanged
- device state changed/ select device rainSensor/ pick any property that changes ==> action: action group under number 2. rainsensorToVariables
4. I guess you use applescript. there you then can access all the variables...
Fri Aug 23, 2013 11:01 am
otto-mate offline
Re: RFXTRX compatible doorbell?
durosity wrote:
I use a HomeEasy HE-306 doorbell with mine.. works perfectly.. just a shame it’s so ugly!
Hi durosity
Can you tell me which options you used to setup the HomeEasy HE306 under the RFXCOM Indigo plugin?
M.
Fri Aug 23, 2013 11:14 am
durosity offline
otto-mate wrote:
Hi durosity
M.
I have two devices setup in Indigo, one is the doorbell button and one is the ringer bit itself. The ringer is setup as a AC Appliance (New KaKu) with a random house code/unit which was sent to the device when in pairing mode. As for the button, it’s setup as a X10 switch with the relevant house code and unit code as it showed up in the logs with ‘Enable debug logging’ enabled (In my case N8).
Just for reference you don’t need the ringer to be paired for the doorbell to keep working, I just paired it in case i ever wanted to remotely ring the doorbell or for future triggers that i may think up in the future.
Sat Aug 24, 2013 12:14 pm
otto-mate offline
Many thanks durosity, I'll give that a go.
M.
Sat Aug 24, 2013 12:34 pm
durosity offline
If you’re looking for something that’s a bit better looking, i believe that B&Q sell siemens branded LWRF compatible doorbells.. but i’ve never actually tried them.
Tue Aug 27, 2013 12:15 pm
pikelet offline
I tried one of the Siemens ones; there's no indication that they're LWRF compatible apart from some in-store advertising boards that carry the logo. I couldn't find anyone specifically saying that they'd made one work with an RFXCOM unit (here or on the LWRF forums), but took a punt regardless. I couldn't get it to be recognised by the RFX plugin in Indigo, so it barely lasted a day before it went back to the shop.
Tue Aug 27, 2013 12:18 pm
durosity offline
Yeah, i found this while looking into it: http://lightwaverfcommunity.org.uk/foru ... lls-in-bq/ . In it it confirms that siemens removed the LWRF code from them.. and that LWRF themselves were going to have their own versions, but looks like they never did. Shame they’re pretty unreliable at shipping anything.. the finish of their products is always so nice.
Wed Sep 11, 2013 3:19 am
col offline
Hi, I am having problems getting my new new RFXtrx433 working, I am running a new mac mini with 10.8.4 and have installed the FTDI driver and the latest plugin, I can see the RFXtrx433 in the configure RFXCOM BOX and appears to initialise.
I can't see the RFX in the preferences or see it mentioned in the available interfaces, any ideas?
Starting plugin "RFXCOM 1.3.6" (pid 478)
Started plugin "RFXCOM 1.3.6"
RFXCOM initializing communication on port /dev/cu.usbserial-A1WRS8F9 at speed 38400
RFXCOM connected to RFXtrx 433.92 MHz, firmware version 67
RFXCOM currently enabled receiver protocols: LightwaveRF, HomeEasy EU, X10
Thu Sep 12, 2013 5:15 am
col offline
Solved
Sun Jun 15, 2014 4:51 am
RJdeKok offline
A new version of the RFXTRX plugin (1.4.0) is available here: -- link removed – use link on first post for most recent version --
Changes in the RFXCOM Plugin:
Support for Somfy (Close=On, Open=Off, Stop and Program)
Stop function for RollerTrol
Completed the list of receiver protocols in the configuration
Added Livolo dimmer (not tested)
Added RGB TRC02 dimmer (not tested)
Added ELRO Appliance
Added several 'actions' to the plugin:
Open RollerTrol
Stop RollerTrol
Close RollerTrol
Program RollerTrol
Limit RollerTrol
Open Somfy
Stop Somfy
Close Somfy
Program Somfy
Color +
Color -
Added several menu items to the plugin:
Program Somfy...
Stop Somfy..
Stop RollerTrol...
Color +
Color-
Sun Jun 15, 2014 12:39 pm
Hans offline
Thank you very much Robert! My Somfy sun blinds are working with Indigo and the RFXtrx433E.
The Open, CLOSE and STOP are functioning by adding specific rfxcom actions to the control pages. For open en close you can also use the on/off toggle for the device.
On page 28 of the RFXtrx user guide you'll find a description how to pair the Somfy with the RFXCom.
Again, many thanks!!
Sat Jun 21, 2014 8:35 am
bluepine offline
Thank you for the update. :D
Sat Jun 28, 2014 9:36 am
moomin offline
Sorry to report but for the first time ever I'm having issues with this plugin.
V1.4 just will not interface with the USB driver properly. Tried reloads, re-boots, un-plug etc, just no go.
Dropped down a version and all is good again, but no Somfy:((
Perhaps soon.
Sat Jun 28, 2014 5:14 pm
Sevilsivle offline
I also had some issues after updating the Plug-In.
You may have to make some changes to the protocols actives in the plug-in.
regards
Tim
Page 4 of 10 1, 2, 3, 4, 5, 6, 7 ... 10
