cconrad wrote:... What's the dot notation in '4.1.2' about? ...
- LMS_Example.png (163.04 KiB) Viewed 6731 times
In the example LMS screen print above (from the web interface), I have hovered the mouse over the track and you will see that in the pop-up in the bottom of the screen is the file name which contains an index of 3.1.0.
3 = 'Testing Favourites' folder
1 = 'Sub-FOLDER-Testing' folder
0 = the flac file
So it really only applies (I think) if you are using sub-folders in favorites.
On the LMS home page, you can edit favorites and add folders by selecting Favorites and clicking on the pencil mark as shown below:
- Edit_Favorites.png (8.64 KiB) Viewed 6731 times
Hope this helps
