Korey wrote:...New unit:
"The IrrigationCaddy IC-W1 (IC) device is a WiFi enabled web based irrigation control system."
http://irrigationcaddy.com/features
+ up to 43 zones!!
whizzosoftware wrote:It was a late night, but here's the link to the first version
http://www.whizzosoftware.com/forums/blog/1/entry-54-indigo-irrigation-caddy-plugin/
Don C wrote:Whizzo: any chance the plugin can be updated to work with the wireless irrigation caddy? I got one and tied the plugin but other than turning the unit off/on none of the other features seem to work. Thank you for all your hard work!
Don
Feb 23, 2014 3:41:21 PM
Reloading plugin "Irrigation Caddy 1.0"
Stopping plugin "Irrigation Caddy 1.0" (pid 6647)
Stopped plugin "Irrigation Caddy 1.0"
Starting plugin "Irrigation Caddy 1.0" (pid 7218)
Started plugin "Irrigation Caddy 1.0"
Irrigation Caddy Debug startup called
Irrigation Caddy Debug Starting device: Irrigation
Irrigation Caddy Debug Requesting status JSON
Feb 23, 2014 3:42:39 PM
Irrigation Caddy Error Error getting Irrigation Caddy (Irrigation ) status (Irrigation Caddy isn't running): <urlopen error (60, 'Operation timed out')>
Irrigation Caddy Debug Starting polling thread
Feb 23, 2014 3:43:39 PM
Feb 23, 2014 3:44:21 PM
Irrigation Caddy Debug Received status JSON: {"zoneNumber":0,"progNumber":0,"allowRun":true,"running":false,"useCloud":false,"cloudConn":"ok","useSensor1":false,"isSensor1Open":false,"isRaining":false,"useSensor2":false,"useMaster":true,"flowRate":0.00,"flowVolumeSec":0,"flowVolume":0.00,"zoneSecLeft":0,"progSecLeft":0,"expBlocks":[],"maxZones":10,"totalZones":11,"zoneLog":[{"zoneNumber":4,"timestamp":446485135,"offset":88.00},{"zoneNumber":2,"timestamp":446484941,"offset":78.00},{"zoneNumber":3,"timestamp":446485020,"offset":114.00}]}
Feb 23, 2014 3:45:21 PM
Irrigation Caddy Debug Received status JSON: {"zoneNumber":1,"progNumber":6,"allowRun":true,"running":true,"useCloud":false,"cloudConn":"ok","useSensor1":false,"isSensor1Open":false,"isRaining":false,"useSensor2":false,"useMaster":true,"flowRate":0.00,"flowVolumeSec":0,"flowVolume":0.00,"zoneSecLeft":590,"progSecLeft":1730,"expBlocks":[],"maxZones":10,"totalZones":11,"zoneLog":[{"zoneNumber":1,"timestamp":446485510,"offset":10.00},{"zoneNumber":4,"timestamp":446485135,"offset":88.00},{"zoneNumber":2,"timestamp":446484941,"offset":78.00},{"zoneNumber":3,"timestamp":446485020,"offset":114.00}],"zones": [{"isRun":true,"hr":0,"min":10},{"isRun":true,"hr":0,"min":6},{"isRun":true,"hr":0,"min":5},{"isRun":true,"hr":0,"min":4},{"isRun":true,"hr":0,"min":4},{"isRun":true,"hr":0,"min":0},{"isRun":true,"hr":0,"min":0},{"isRun":true,"hr":0,"min":0},{"isRun":true,"hr":0,"min":0},{"isRun":true,"hr":0,"min":0},{"isRun":true,"hr":0,"min":0}]}
Feb 23, 2014 3:46:21 PM
Irrigation Caddy Debug Received status JSON: {"zoneNumber":4,"progNumber":6,"allowRun":true,"running":true,"useCloud":false,"cloudConn":"ok","useSensor1":false,"isSensor1Open":false,"isRaining":false,"useSensor2":false,"useMaster":true,"flowRate":0.00,"flowVolumeSec":0,"flowVolume":0.00,"zoneSecLeft":235,"progSecLeft":475,"expBlocks":[],"maxZones":10,"totalZones":11,"zoneLog":[{"zoneNumber":4,"timestamp":446485575,"offset":5.00},{"zoneNumber":3,"timestamp":446485562,"offset":12.00},{"zoneNumber":1,"timestamp":446485510,"offset":39.00},{"zoneNumber":2,"timestamp":446485550,"offset":11.00}],"zones": [{"isRun":false,"hr":0,"min":10},{"isRun":false,"hr":0,"min":6},{"isRun":false,"hr":0,"min":5},{"isRun":true,"hr":0,"min":4},{"isRun":true,"hr":0,"min":4},{"isRun":true,"hr":0,"min":0},{"isRun":true,"hr":0,"min":0},{"isRun":true,"hr":0,"min":0},{"isRun":true,"hr":0,"min":0},{"isRun":true,"hr":0,"min":0},{"isRun":true,"hr":0,"min":0}]}
Feb 23, 2014 3:47:21 PM
Irrigation Caddy Debug Received status JSON: {"zoneNumber":5,"progNumber":6,"allowRun":true,"running":true,"useCloud":false,"cloudConn":"ok","useSensor1":false,"isSensor1Open":false,"isRaining":false,"useSensor2":false,"useMaster":true,"flowRate":0.00,"flowVolumeSec":0,"flowVolume":0.00,"zoneSecLeft":220,"progSecLeft":220,"expBlocks":[],"maxZones":10,"totalZones":11,"zoneLog":[{"zoneNumber":5,"timestamp":446485586,"offset":55.00},{"zoneNumber":3,"timestamp":446485562,"offset":12.00},{"zoneNumber":4,"timestamp":446485575,"offset":10.00},{"zoneNumber":2,"timestamp":446485550,"offset":11.00}],"zones": [{"isRun":false,"hr":0,"min":10},{"isRun":false,"hr":0,"min":6},{"isRun":false,"hr":0,"min":5},{"isRun":false,"hr":0,"min":4},{"isRun":true,"hr":0,"min":4},{"isRun":true,"hr":0,"min":0},{"isRun":true,"hr":0,"min":0},{"isRun":true,"hr":0,"min":0},{"isRun":true,"hr":0,"min":0},{"isRun":true,"hr":0,"min":0},{"isRun":true,"hr":0,"min":0}]}
Feb 23, 2014 3:48:21 PM
Irrigation Caddy Debug Received status JSON: {"zoneNumber":5,"progNumber":6,"allowRun":true,"running":true,"useCloud":false,"cloudConn":"ok","useSensor1":false,"isSensor1Open":false,"isRaining":false,"useSensor2":false,"useMaster":true,"flowRate":0.00,"flowVolumeSec":0,"flowVolume":0.00,"zoneSecLeft":160,"progSecLeft":160,"expBlocks":[],"maxZones":10,"totalZones":11,"zoneLog":[{"zoneNumber":5,"timestamp":446485586,"offset":115.00},{"zoneNumber":3,"timestamp":446485562,"offset":12.00},{"zoneNumber":4,"timestamp":446485575,"offset":10.00},{"zoneNumber":2,"timestamp":446485550,"offset":11.00}],"zones": [{"isRun":false,"hr":0,"min":10},{"isRun":false,"hr":0,"min":6},{"isRun":false,"hr":0,"min":5},{"isRun":false,"hr":0,"min":4},{"isRun":true,"hr":0,"min":4},{"isRun":true,"hr":0,"min":0},{"isRun":true,"hr":0,"min":0},{"isRun":true,"hr":0,"min":0},{"isRun":true,"hr":0,"min":0},{"isRun":true,"hr":0,"min":0},{"isRun":true,"hr":0,"min":0}]}
Feb 23, 2014 3:49:21 PM
Irrigation Caddy Debug Received status JSON: {"zoneNumber":5,"progNumber":6,"allowRun":true,"running":true,"useCloud":false,"cloudConn":"ok","useSensor1":false,"isSensor1Open":false,"isRaining":false,"useSensor2":false,"useMaster":true,"flowRate":0.00,"flowVolumeSec":0,"flowVolume":0.00,"zoneSecLeft":97,"progSecLeft":97,"expBlocks":[],"maxZones":10,"totalZones":11,"zoneLog":[{"zoneNumber":5,"timestamp":446485586,"offset":178.00},{"zoneNumber":3,"timestamp":446485562,"offset":12.00},{"zoneNumber":4,"timestamp":446485575,"offset":10.00},{"zoneNumber":2,"timestamp":446485550,"offset":11.00}],"zones": [{"isRun":false,"hr":0,"min":10},{"isRun":false,"hr":0,"min":6},{"isRun":false,"hr":0,"min":5},{"isRun":false,"hr":0,"min":4},{"isRun":true,"hr":0,"min":4},{"isRun":true,"hr":0,"min":0},{"isRun":true,"hr":0,"min":0},{"isRun":true,"hr":0,"min":0},{"isRun":true,"hr":0,"min":0},{"isRun":true,"hr":0,"min":0},{"isRun":true,"hr":0,"min":0}]}
Feb 23, 2014 3:50:25 PM
Irrigation Caddy Debug Received status JSON: {"zoneNumber":5,"progNumber":6,"allowRun":true,"running":true,"useCloud":false,"cloudConn":"ok","useSensor1":false,"isSensor1Open":false,"isRaining":false,"useSensor2":false,"useMaster":true,"flowRate":0.00,"flowVolumeSec":0,"flowVolume":0.00,"zoneSecLeft":37,"progSecLeft":37,"expBlocks":[],"maxZones":10,"totalZones":11,"zoneLog":[{"zoneNumber":5,"timestamp":446485586,"offset":238.00},{"zoneNumber":3,"timestamp":446485562,"offset":12.00},{"zoneNumber":4,"timestamp":446485575,"offset":10.00},{"zoneNumber":2,"timestamp":446485550,"offset":11.00}],"zones": [{"isRun":false,"hr":0,"min":10},{"isRun":false,"hr":0,"min":6},{"isRun":false,"hr":0,"min":5},{"isRun":false,"hr":0,"min":4},{"isRun":true,"hr":0,"min":4},{"isRun":true,"hr":0,"min":0},{"isRun":true,"hr":0,"min":0},{"isRun":true,"hr":0,"min":0},{"isRun":true,"hr":0,"min":0},{"isRun":true,"hr":0,"min":0},{"isRun":true,"hr":0,"min":0}]}
Feb 23, 2014 3:51:25 PM
Irrigation Caddy Debug Received status JSON: {"zoneNumber":0,"progNumber":0,"allowRun":true,"running":false,"useCloud":false,"cloudConn":"ok","useSensor1":false,"isSensor1Open":false,"isRaining":false,"useSensor2":false,"useMaster":true,"flowRate":0.00,"flowVolumeSec":0,"flowVolume":0.00,"zoneSecLeft":0,"progSecLeft":0,"expBlocks":[],"maxZones":10,"totalZones":11,"zoneLog":[{"zoneNumber":3,"timestamp":446485562,"offset":12.00},{"zoneNumber":4,"timestamp":446485575,"offset":10.00},{"zoneNumber":5,"timestamp":446485586,"offset":275.00}]}
Trigger aaa irrigation
Email Sent to "korey.sherwin@xxxx.com"; subject "irrigation test"
Feb 23, 2014 3:52:25 PM
Feb 23, 2014 3:53:25 PM
Smashim wrote:With debug enabled I also see this error : Irrigation Caddy Error Error sending "Run Program" action to Irrigation Caddy (Irrigation Caddy): HTTP Error 404: Not found
curl -d 'allowRun=yes&doProgram=1&z1durMin=4&pgmNum=5&runNow=1' http://<YOUR IC ADDRESS>/program.htm
curl -d 'stop=active' <YOUR IC ADDRESS>/stopSprinklers.htm
