matt (support) wrote:Note the Event Log plugin could probably be modified to handle the unicode character correctly. It might just need to use a unicode string (u"") instead of an ascii string ("") somewhere. I'm not familiar with the code though and it isn't obvious from the stack trace in your event log as to where the problem is specifically.
Unicode can be a pain. I'm having issues with it with some Image gallery software that I'm working on.
The true fix is Python v3 (completely Unicode based), but for v2 the unidecode library is excellent for mapping unicode to ascii.
That being said, I am starting to rework or re-evaluate some of the older plugins, and decide what I need to do to update them.
By the way, I just realized that my RSS feeds were killed when you migrated to the newer version of the forum software.
I would suggest that you point out somewhere that the complete
RSS feed is available from the pull down. I was concerned that I would have to add 30+ feeds so that I could monitor the forums I need to view.
